This is starting to drive me crazy. Headlight randomly flicker and die only to work again hours or days later.
I was told this is common, and to disconnect and reconnect the battery. I did it and it worked fine for weeks. Then flicker and dead again.
What’s the real fix?
Buy a Chevrolet. (Not really)
Are you talking stock lights or LEDs?
2014 JKU, 35's, 3" Lift
Both headlights, or just one of them? I switched my lenses to glass Cibie models and bulbs to H4's. The small pigtail I used to switch from the OE H13 to H4 had a bad pin and the bulb would regularly "die". If it's only one, might want to check the connection.
It’s both in unison.
