Timmy
· Registered
Discussion starter · #1 ·
So my 07 headlights flicker and won't turn off. Already replaced the multifunction switch. Right now both multifunction switches are disconnected and the headlights are on. Anyone have any other ideas?
No input available from the multifunction switch will cause the headlights to come on as a fail-safe feature.
Loss of CAN bus communication will do the same thing.
The best way to troubleshoot the headlight system is with the dealer scan tool because the system involves CAN and LIN communications to the TIPM.
Their scan tool can monitor communications and point out where the problem is. Otherwise, you can use a DMM to check for continuity at different points along the various circuits.
