NEWB here...first post. Glad to be part of the community!
Anyone have a tip for replacing the headlamps on a 2007 JK? Looks like I need to remove the horn on the driver side and the power steering resevoir on passenger side to get at the harness. Has to be a better way! Any help is appreciated.
Thanks much,
JS
irate4x4 dot com
no need to remove the horn. Just remove the single bolt for the power steering reservoir, but I'm not sure that's necessary.
Sorry, I don't remember much detail, but I took mine in and out 2 or 3 times and if I can easily do it and not remember it being a big deal, it must be easy.
Take the grill off, undo the plugs to the turn signal to fully remove it and then it seems like there is a ring around the headlight with 2 little screws to remove and the light will come forward enough to disengage the plug.
its easier to pull the grill and take the 3 screws a piece off of the retaining rings and pull the whole headlight out to access the bulbs than to try to get to the bulbs from the back
