1 - 12 of 12 Posts
I recently got a new job that requires me to go on the highway and I noticed a very aggressive wobble at speeds over 55, its consistent throughout after 55. Looking to see if I can locate it.
I have a 2007 2dr, here is what I have done to my suspension:
RK progressive 2.5 springs
Bilstein 5160 shocks for 2.5 lift.
RC Front forged trackbar
RC rear trackbar bracket
RC front disconnectable links
RC rear links
Core 4x4 tier 2 front lower control arms
My alignment is decent, need to fix the caster a bit to bring it to 4.5 cause I'm at 4.2 and 4.3 right now.
My passenger side rear shock is shot, got a new rear set and I just have to swap them out when I get time.
Could the shock be causing this? Any help would be great because I keep finding threads about death wobble in search for an answer and I most definitely don't have death wobble. It happens on a very smooth highway with no bumps and I can stop it from happening if I slow down to under 55.
Sent from my SM-N960U using Tapatalk
Sounds like a tire balance issue
Speed related is a good indicator it's a tire/balance issue.
Thanks for the replies guys, went I went back to townfair for a balance they told me that on larger tires they use this stuff that they put on the inside to balance tires, they don't actually put weights on the wheels. I'll go back just in case but I do have 35 inch general grabber tax. Appreciate the help.
What type/size tire?
Can you borrow a set that you know is true/balanced?
Also great idea, my stockies that I use for inspections are definitely balanced, I can use them to see if it's definitely that.
Dynabeads? Those worked for the most part for me on my last set of tires (35s), minus a small occasional wobble around 50.
There's no reason they can't do a regular balance with larger tires though. In my experience it works better. However depending on the tire it seems that the dynamic balance is just too much weight and they can do a static balance instead.
On my current set of 37s, the machine had them putting upwards of 25oz with the dynamic balance, but the static balance was only 6-9 oz and is smooth as glass.
I agree this sounds like a lack of tire balance issue - or a poorly balanced tire issue.
Several factors go into whether or not a shop can balance your tires. Is their equipment large enough to fit the tire -and- can they collar your rim. Meaning is the hole in the center of your rim too large for them to use on their equipment. Some rims have center holes too large to collar on standard tire balancing equipment.
35s are small enough tires they should have used external weights - no matter what. For 37s and larger tires, they do some times use internal weights but don't let them. If your shop wants to go that route go somewhere else. Even a national chain like Tires Plus can do a good job and do it correct with external weights - and get the tires in balance with 37s. As long, of course, as you don't have 8x6.5 rims with massive centers that they can't find collars for. You know, so they can hold the rims on the machines with.
Discussion Starter #9 (Edited)
Thank you guys for these super informative replies. I am going in to get the tires balanced anyways but, this morning I did take the time to replace my passenger side rear shock which was leaking, while at it I replaced the driver's side just so they match and the wobble is gone. Some more shaking comes back at maybe 80 but I don't go that fast anyways and I think it's more of a "jeep thing" than an actual issue because it's more of the whole jeep shaking a tiny tiny bit. I think it's fixed but I'm definitely gonna go get a real balance.
Yeah, not a bad idea to get the tires balanced anyway. It is a rare thing for that kind of shimmy to be caused by a leaking rear shock.
Especially when the shake is speed induced at a certain range/condition and not constant.
Better safe than sorry!
Discussion Starter #11
Those are very wise words, i just had to put a whole new tranny in because i didn't necessarily do that before with a transmission leak. Thanks for your help man
Step 1, check tyres for balance & out of round. I had a set that was perfectly balanced but still caused vibration because they were not perfectly round any more.
Step 2, fix the caster. As I commented on Wranglerforum yesterday, I have had this sort of thing, particularly after hitting an angled bump on the road at that speed range, & it felt almost as bad as true DW, but was just steering shimmy due to the caster angle being too low.
1 - 12 of 12 Posts
