Does anyone know if a 2012 JKU hardtop will fit on a 2015 JKU?
Getting a good deal on one, just want to make sure the trip will be worth it!
Yes, should have no problem.
The only hardtop that was different was the first couple of years (07-09 I believe); and even then they still fit fine; just the footman loop was in a different spot.
I run the hard top from my 2010 on my 2015 if that helps to answer your question. Make sure you get the "nuts" from under the frame rail when you get the bolts for the hardtop. If your current jeep came with soft top only you'll be missing those.
