Im sure this has been covered. Just cant find it. Im looking to purchase a hard top for my 2015 jkur. Not worried about rear defrost or wiper. What hardware do I need ? Do I have to drill any holes ? Will it be easy to just put the soft top back on in the spring ? thnx.
You shouldn't need to drill any holes. If the hard top doesn't include it, you will need the bolts/nuts to fasten the top down. They are available lots of places on-line. The versions with wing-bolts are handy for tool-less install/removal.
You can swap back to your soft top any time.
hard top/soft top are interchangeable. If you buy a hardtop, most likely it will come with everything you need. The wiring dongle is probably already on your jeep and tucked away behind the rear passenger side (where the seat belt mechanism is). On the rear driver side, you will find the washer fluid connector. Super easy to connect/disconnect everything. Just use common sense as you go.
Look into a hoist system for your garage. Much easier on your back.
