1 - 14 of 14 Posts
I am new to the hard top. Has anyone come up with a cheap easy way to hoist their hard top. I have seen the ones you can buy and they seem pricey. I was thinking to set up some sort of block and tackle to lift mine on the cheap. Anyone seen anything on that? Also. I have seen the tumb screws to make removing easier. Are those the best or are there some other quick disconnects?
thanks
Steve
See my sig for a good DIY solution ... makes it a simple one-man job to hoist it off the Jeep and store it safely.
Please post your DIY option for those of us banned at the other forum - thanks!
One of the best I've seen, pretty much exactly what I'd like to do - thanks for the post!
Home made lift
I just bought 1 1/4 inch square 14 gauge tubing and welded it up in the shape of an I then drilled and mounted eye bolts and strap this to the top and re strung a come a long with 30 ft of cable. I then used several pullies to change the diretion and used eye lag bolts to mount it in the garage. Works like a charm and cost about 75.00 total. hope this helps. Chris
Any pics?
14ers
what about storage?
Anyone try one of those racks you can whell around and also put the doors on? I don't want to suspend mine from the ceiling. I already have too many scars on top :shaking:
1 - 14 of 14 Posts
