1 - 1 of 1 Posts
Yeasu FT-90r compact dual band Ham Radio
2m/440 operation
MARS modified
comes with the remote head kit. (you need your own speaker.... buy it quick and i'll toss in a old GE remote speaker)
it needs a new mic cable. it still works with mine, but the coiled cable liner came apart. it has been used in a couple of different vehicles, and i've enjoyed it. i've reached the point that i dont need it anymore... and i've let it sit around a long time. i will not reset the rig, so it will come with all of my stored channels in it. you can clear it out on your own if you like....
the only thing it will not come with is the owners manual. it has been lost/found/lost so many times... :rolleyes: the manual can be found and downloaded online in .pdf format. such as [URLhttp://www.pcecg.org/yaesuft90.pdf]here.[/URL]
General
Frequency Ranges: RX: 100~230 MHz, 300~530 MHz, 810~999.975 MHz*
TX: 144-146 MHz or 144-148 MHz (144 MHz)
430-440 MHz or 430-450 MHz (430 MHz)
Channel Steps: 5/10/12.5/15/20/25/50 kHz
Emission Type: F3, F2, F1
Antenna Impedance: 50 W, Unbalanced (Antenna Duplexer built-in)
Frequency Stability: ±5 ppm (–5 °C to +60 °C)
Operating Temp. Range: –20 °C to +60 °C
Supply Voltage: DC 13.8 V ±15 %, Negative Ground
Current Consumption (approx):
350 mA (Receive, Squelched)
9.5 A (Tx, 144 MHz)
8.5 A (Tx, 430 MHz)
Case Size: 100(W) x 30(H) x 138(D) mm (w/o knobs)
Weight: 640 g (1.41 lb.)
* Cellular and digital telephone frequencies are blocked and cannot be restored.
Transmitter
RF Power Output: 50/20/10/5 W (144 MHz), 35/20/10/5 W (430 MHz)
Modulation Type: Variable Reactance
Maximum Deviation: ±5 kHz
Spurious Emissions: At least 60 dB below fundamental
Microphone Impedance: 2 kW
Receiver
Circuit Type: Double-Conversion Superheterodyne
Intermediate Frequencies: 45.05 MHz and 455 kHz
Sensitivity: 0.18 μV @12 dB SINAD
Selectivity: 12 kHz/24 kHz (–6 dB/–60 dB)
AF Output: 2 W @ 8 W for 10 % THD
AF Output Impedance: 4 W – 16 W
$200 shipped
Yeasu FT-90
http://www.eham.net/reviews/detail/75
for an additional $75, i'll include a dual band antenna, heavy duty all-angle trunk-lip mount and heavy duty cable. mount is similar to the Diamond K-400C....
also have a older Magellan Map330... with a DC/serial cable and cradle. the suction cup/post part of it was broken. cradle is good though. was asking $75 obo individually... package deal, i'll toss it in with the radio for $30
1 - 1 of 1 Posts
