1 - 10 of 10 Posts
I'm going to pick up some grease and a gun to add to my tools. When I looked up the Synergy Grease this comes up and shows "frequently bought together": Amazon: Synergy Grease & Lumax Grease gun bought together
Any thoughts on the grease gun or do you recommend a particular model/type?
Also, which one would you choose...Synergy Grease or Amsoil Synthetic Polymeric Off-Road Grease...or do you recommend another particular brand (specific product)?
I don't have to have the most expensive or the absolute top of the line, but I do like to buy quality. Thanks.
Discussion Starter #2
Also, any preference as to pistol grip or lever style gun?
A pistol grip grease gun can be found cheap at any farm store, home depot type store or harbor freight. I use Lucas Red-n-tacky for most stuff, but have used Mobil synthetic on things like ball joints and u-joints with good success.
for balljoints from synergy to be wrrnty covered for a year , they recommend their high heat poly grease ; the stuff makes PAM feel like Velcro ... it is the slickest most durable consistency stuff I've ever felt ... I use it on the Synergy BJs and bushings and then thev Lucas red-n-tacky every place else . I run a greased pig.....
and oh , pistol grip + 90 ° right angle grease fitting + a needle grease fitting for things like double Cardan cv in middle of the driveshaft or lower balljoints is good idea while your splurging on greases.....
I have Synergy tie rod/drag link/track bar. RK control arms with krawler joints. Rare Parts ball joints. RK rear track bar.
RK recommends a marine grease, Synergy recommends their grease, Rare parts recommends amsoil but Robbs2008JK said they told him Lucas was ok, which makes me ask can I just use the Lucas red n tacky #2 on everything and be ok?
http://www.northerntool.com/shop/tools/product_14319_14319 anyone use this? worth a damn for $29?
I've been using Synergy's grease in everything.
I try to find grease that is NGLI rated to GC-LB (see below for explanation) and is an aluminum-complex grease (look at the ingredients). This type of grease has excellent performance when there's a chance of water contamination
Way prefer the pistol grip type. I'm still using a manual-pump... maybe I'll get an air-driven one one day. The list of stuff to grease on my rig and on the F350 is pretty long anymore.
G - Certified for use in automotive wheel bearings
--- A - Good
--- B - Better
--- C - Best
L - Certified for use in automotive chassis
--- A - Good
--- B - Best
+1 for the Synergy grease. Used to use the Lucas Red grease and it would melt/separate just sitting on the garage shelf.
Also bit the bullet on a DeWalt cordless electric grease gun after dealing with a couple of the lower priced manual grease guns. One of those tools that makes you smile every time you use it and the price tag has long been forgotten.
it's the sh*t , for certain. It's so thick a glob will hang for a day on an inverted spoon but I swear I think if you covered the floor with a thin layer you could ice skate across it without problem....it be some kinda grease .....( get what ya pay for )
1 - 10 of 10 Posts
