1 - 20 of 89 Posts
Story:
I bought my JK new back in '07 it's an unlimited X. She now has 115,000 miles, with lots and lots of wheeling under her belt. It's a pretty run of the mill jeep w/ lift, 35's, winch bumper, winch, sliders.... I stopped wheeling this jeep May of '09 (thats when I finished my TJ crawler). Well, all the wheeling has taken a toll on the old gal and about a year ago I retired her from my d/d and started just using her as a weekender. The problems this jeep has now is enough to make me feel unsafe driving it at highway speeds and far distances. My goals now are to make the jeep road worthy again, and make it fun and safe to take on a road trip that is coming up in August (2400 miles round trip).
Problems:
serious front axle issues; ball joints, possible bent housing, and wallered out trackbar bracket(this is a re-inforced one that I welded on).
rear axle floats from side to side while going down the road.
constant death wobble (probably has to do with the front axle).
lots of creaks and clatters going down the road.
bushings out on the entire suspension.
pass side axle shaft has egged yoke on the outer.
top is ruined.
drivers seat has a bad tear.
is a gutless turd that gets bad mpg.
rear shocks are blown out.
front drive shaft is destroyed(this is the second oem).
sway bar discos are pretty f-d up
My hopes as a newb to this site is to get tips and advice on repairs required to fix the problems above(i figured this site probably has some guys that have broken a JK before since this site is tied to pirate). I'm doing 95% of the work myself, which is part of owning a jeep (I built my crawler with a couple friends in my shop). I am just hoping that maybe some of you experienced the same issues as I did. I was a member on JK-Forum since the beginning, but haven't posted on there in a long time, cuz it kinda turned into a whos jeep has the most useless junk contest over there......
Parts on order:
Bestop Treck top NX,
Bilstein 5100 shocks for rear,
First thing I would address is the front axle: shafts (either new or see if somebody has some stock spares they'll sell you), new Poly Performance ball joints, and replace the track bar brackets on the frame and axle.
Then tackle replacing all the bushings or just getting some new control arms.
The first real obstacle on my to do list is the front axle. I'm not really sure if the housing is bent, but the balljoints are only about a year old w/ lest than 10k miles and one light wheeling trip on them. yet the tires are still leaning in at the top. which makes me wonder if the c's are bent. I have had my jeep in a front end shop and they spect it and said the balljoints are good (this was about 6 months ago. I have one new wheel bearing on the driver side.
I would like to find a complete d30 used that some one took out of theirs and slap it under mine. How ever, I have realized in the last week that they go super fast and if they haven't sold it's cuz they are probably not much better than mine.
I posted my last post before I saw this one.
Once I find out if my axle is bad or not, I plan to do just that.
I'm designing my new track bar brackets right now, which hopefully when I get these designed and built they will withstand the tests of time.
I just got back from the alignment shop and this is what the report shows....
Camber: Left-1.2 right- 1.6
toe: Left--1.74* right- -1.94*
Camber specs for my jeep are supposed to be.....
camber: left- -.6 to .1 right- same as left
toe: left- .009 to .12 right- same as left
In the report they said my driver side upper and lower balljoints are slightly loose. Also, that the front axle is most likely bent due to the extreme camber angles!
So long story short, my front axle is junk! Time to hunt for a d30 w/ 4.10 gears or maybe 4.88's and I'll regear the rear to match......
just thinking out loud here but if you lifted it and don't have adjustable control arms your inner c's are not orientated in the right spot causing your camber to be out of spec.
I'm not sure on that, but I plan to buy new control arms. I'm not sure who I will buy from, but I know the uppers will be adjustable...
what he said....if you have anykind of lift without adj controll arms your camber will be out, but it should be out the same on both sides, the bigger the lift the more it will be out. ever think about looking into something better than another 30?
Discussion Starter #10
Thanks to y'alls advice I'm going to plumb bob the axle tonight and get exact measurments to find out if it's bent or not.
As far as upgrading from the turdy... I thought about it, but I dont really feel it's necessary. I have a jeep with 2 steering rockwells, and the need to make this one beefier isn't really there.
Discussion Starter #12
I'm a picture posting whore..........
My JK(with the old rims and tires) pulling my crawler.... Only for fun... not actual tow rig...lol
This was my JK less than a week old....
Just giving an idea, I wasn't easy on her.....
How she looks today, except the top has no windows...
My Crawler: '99 TJ, steering rocks, 4 link, king triple stage coil overs, teralow, and lots and lots of tubing....
and me....
and last... my CJ-5 that started it all.... I've had it since I was 14...
days after I got it...
LOTS AND LOTS OF WORK....... AND THIS........
Discussion Starter #15
Those are some nice jeeps. Welcome to JKO!
edit* are those pics of your tj at Barnwell?
Thanks...
Yup, that's at BMRA. I've been going there for about 5 or 6 years now. It's a fun park, I haven't missed a Mega Run in 5 years. Although, some of the people that were running the event pissed me off this year, so I dont know if I'll be back.
Discussion Starter #16
Well, after doing a crap load of measurements, it looks like I bent my front axle where the C's mount to the axle tube. So, the hunt for a new housing is on.
While waiting on finding my new front axle I'm going to go a head and order some other parts. I think I am going to order my control arms, and just do away with the factory control arms. I think I'm going to go with WP lowers and currie uppers. I'm not doing currie lowers cuz that would run me about $1200 in control arms.... :shaking:.
I'm also going to order my new trackbars today. It will be TeraFlex front and rear. I already have a teraflex in front, but it's pretty much worn out. The rear, I can't remember what brand it is.....
I'm prolly going to order my sway bar disco's as well.....
Discussion Starter #17
I just ordered some stuff from Krawloff-road.com. Jason over there made me a good deal on some items and is very friendly to deal with and has been super fast at replying to my e-mails. I can't wait to get my stuff in the mail and do more business with him in the future.
List of items I bought:
RK02015 - RK JK High Clearance Adjustable Front Lower Control Arms
RK02020 - RK JK Adjustable Front Upper Control Arms
RK02022 - RK JK High Clearance Adjustable Rear Lower Control Arms
RK02028 - RK JK Double Adjustable Rear Upper Control Arms
RK02024 - RK JK 2" to 4" Double Adjustable Front Track Bar
RKJKC0001 - RK JK Bomb Proof Rear Double Adjustable Track Bar and Bracket
That's a sweet set of parts coming. I'll be doing control arms soon and like the RK stuff. I'd like to see some install pics and get your opinion of them once they are installed.
Thanks...
I recognized the rock garden. I live about 20 minutes from there. I've never run any events there, just gone up and camped and fooled around. I do love that place.
1 - 20 of 89 Posts
