Status
Not open for further replies.
1 - 20 of 105 Posts
Made in the U.S.A.
Here are the rules:
- JKOwners.com giveaway rule - You MUST be a JKO supporting member to enter.
- This means you must have a Red, Blue, or Yellow star next to your name both at the time you post and at the time of the drawing.
- If you do not have a star, your post will be deleted.
- If you do not have a star at the time of the drawing, your entry will be DQ'd.
- Post in this thread one time only to enter. If you post more than once you will be DQ'd.
______________________________
CONTEST DURATION
- The GenRight Off-Road Evap Skid Give-Away will run for 30 days starting on 8/8/13 through 9/6/13 with the winner drawn on/about 9/7/13!
**NOTE: No purchase of GenRight Off-Road Products required for this contest
The winner will receive a GenRight Off-Road Evap Canister Skid Plate!
- This is a heavy duty Skid Plate for the plastic evap canister (located under the Jeep JK 2 door and 4 door).
- It is a higher clearance skid than the OEM factory skid (on later model JKs)
- Re-uses all the factory evap canister hardware. Securely bolts to the vehicle for serious off roading.
- Constructed of 3/16" steel.
- Shipped black powder coated.
Awesome part, thanks for the chance to get one!
R.I.P. Mr. Nibbles!
Thanks for the opportunity!
In and thanks.
I'm in also
1 - 20 of 105 Posts
Status
