1 - 20 of 38 Posts
How many JK owners would be interested in a larger Capacity Tank built by Genright. www.genright.com Yes I am a Genright Product Pimp:grinpimp: I know MichaelW has been on me to beat up on Tony for this product but if can show him a list with names of people willing to purchase a tank maybe I can sway him for build after the first of the year.:beer:
Just post up with your comments.
Regards,
Rick
Genright
805.584.8635
I don't care if it's a smaller capacity tank, I just want one that tucks up above the frame rails on my Unlimited. I am very interested, as long as it isn't ridiculously priced. Thanks for asking !
I would be interested, but it's far down my list of mods at the moment. Pretty much
Remodel guest bath
Remodel master bath
landscape yard
pay for kids college prepay
jeep parts...:bawling:
Ron
Broker by the Minute
A larger capacity safari tank would be high on my list!
GenRight makes some top notch shiat!
Larger capacity safari tank tucked up between the frame rails like the TJ tank with bullet proof skid plate and I'm there!
Just don't forget to relocate the evap canister while your down there.
Oh and if you need to remove the JK "trunk" to fit more gas I'm all over that.
Then when you are done, I want a air reserve tank to put in the old gas tank location.
:bounce:
:bounce:
X2!!!!
G
Guest
I'd be very interested in a tank that was flush with the frame rails. There are several inches of clearance wasted with the current arrangement and I'd love to recover them and top it off with a robust skid plate.
If it's possible to increase the capacity, all the much better. I'd even be interested in a split tank arrangement with part of it on each side.
More clearance, tucked up between the frame rails. I would even give up a little capacity for that!!!! Please make one for us.:bounce:
I would love one that is at frame rail level with the same if not more capacity. Or even a split system having one smaller one on the other side.
X2 My thoughts exactly.
Some form of armor option would also be a good idea.
Yes and no. yes it needs to be tucked up more to give back that wasted clearance. But then you have to deal with the skids for the t-case and tranny skids, which are just as low as the gas tank.
Getting the gas tank out of the way is definitely required, especially considering the flimsy skid plate that's on it, but maximize on the clearance the other skids need to be dealt with too.
Sign me up. I had an enduro tank on my TJ. Just get it up to the frame rails and I'll be happy.
Andy
I would get one in a hart beat if it was relocated behind the rear axle. I dont mind if I lose fuel capacity either. They would have to be able to use the stock fuel pump though... thats probably going to be a big deciding factor. Considering how low the stock tank sits, you have to think thats for a reasion. That fuel pump must reach the bottom of the tank. Maybe they could use a TJ or YJ fuel pump assembly? Either way I think I would rather drag the ass-end of my Jeep than the belly.
Come on Gen-Right, build a "bolt in" package with fuel lines and everything needed.
EDIT: I would not mind cutting the floor on the JK to remove that "trunk" and covering the hole witha nice sealed up lid for easy access to the fuel pump......
Discussion Starter #18
Keep the Comments coming:bounce: I got Tony really thinking JK we have some projects that we are finishing up. But I really think after the New Year we might need a JK Here to test fit a few items. Hey Mikey Ready to give up your JK for a few Weeks!:grinpimp:
I'd be interested in having one of these. I'd like it to be flush with the frame rails and with appropriate armor. I don't mind giving up some capacity, but would be equally happy to gain a bit too. The key things would be flush with the rails, armor, and all the necessary pieces parts needed for install. :smokin:
1 - 20 of 38 Posts
