I have a 2008 JK, bought the truck used and had no issues. But after a month i started getting a gascap light. I looked up the code and got a large evap leak, i first checked the gascap and it was good and the seal is tight. I then went under the truck to look at the hoses to the evap system where i noticed that the front (face the front of the truck) of the black box for the evap system has a hole in it. Im going to assume this is my large leak problem. Can someone please confirm this before i go to the dealship and replace something that isnt the problem. Thanks in advance
I would say Yes, the hole in your evap canister is your large evap system leak. Get it replaced and you should be good.
Discussion Starter · #3 ·
Thanks, just didnt want to go spend the money on something that wouldnt fix the problem
You will need to fix the Evap canister but you may be part of the gas tank recall. Check with your dealer.
