1 - 20 of 36 Posts
So I've been looking at lifts and the Full Traction 3" Economy Lift is one of the ones I'm considering. I would like to hear from some people especially with JKUs that are running this. Did you have to make any other modifacations besides the lift itself? How has it affected your driveline? What's the ride like as compared to stock.
Here's a link:
http://www.fulltraction.com/detail.php?MODELID=24&MAKEID=1&TYPEID=1&PRODUCTID=416&NOTES=
Not going to get a lot of positive responses around here about Full Traction. I know you didn't ask for advice on other manufactures but, take a look at Rock Krawler and Synergy Suspension.
thanks, i'll look into all of them. i welcome suggestions. I'm looking for a 2.5 to 3" lift. i wanna run 35's without rubbing if possible.
Vendor
Okay, then for suggestions, look at Rock Krawler, Synergy Suspension, and TeraFlex. All great companies with good reputations. Each of these offer a great starting point to where you can build the lift down the road and add to it as you see fit. With each of these as well, running 35's will not be problem!
Let us know if you have any questions or if we can help in any way!
-Jason
Thanks. I've been looking at Teraflex for awhile now. I'm also consider Rough Country. Rock Crawler and Synergy look like they might be a little out of my budget, but I'm still considering them. My main concern is what happens after the lift is installed. I want to avoid any surprise driveline or suspension component failures. I am planning to run 35's, so as I understand it, a 2.5" lift will work, but may rub, and a 3" inch lift should clear them. I guess the problem is that the higher I go, the more it will affect other driveline/steering/suspension components.
I did the RK 2.5" stock mod with fancy rancho RS9000xl shocks and teraflex bumpstops for mid 700's shipped (that's an approximation on price, i can't remember exactly) from Bustabizz on here. He did free shipping and nobody could touch his price on stuff.
Bilstein 5100's were 20 bucks cheaper overall, but i wanted adjustable.
I'll always push people away from Rough Country- every single thing of theirs that I've worked with has failed or rusted. Their shocks start leaking if you look at them funny, everything seems to rust after one winter up here, and their springs sag if you hit a speedbump.
Being that you're from snow country too, I'd say stay away from Teraflex and Rough Country. TF is great if you don't get salt and sand on your roads, but I've seen nothing but problems with their bushings after winter.
On the other hand, my Rock Krawler stuff was definitely more coin, but has held up like a champ. Spray-lube the end links and Krawler joints, and they'll last forever. Worst case, if one does seize from lack of love, they're a great company to deal with. The fact that they're only an hour north of me helps, so I just stop in for bits as needed :) They also support this forum, and actively post up on here. I will also HIGHLY recommend the Bilstein 5100 shocks- a bit more expensive than some, but worth every penny- they let the JK ride AND handle like a champ, even with 35" KM2's on mine! Amazing- Mark W.
2.5 BB Teraflex
I have a 2.5 Teraflex BB with 295/70 r17 trail graplers(spelling) that are a true 33.6 inch tire. I just came back last night from the badlands in Attica, IN. I took off both front and rear sway bars and I had no rubbing at all. Depending on what tire and rim you are going to run, true tire size will vary. If I could do it again, I should of bought a entry level kit instead of a BB.
Just my .02:beer:
Just my .02:beer:
good info. but why would you take off the rear sway bar? you don't actually get any more articulation, do you?
on the driveshafts, anytime you go over 3" you'll be straining your drivelines and it will have to be addressed sooner or later. the key beneficaries to failing drivelines tend to be, lift height, longer shocks (long travel shocks), disconnecting while off roading, and frequency of off roading.
Yes you do, you can actually test the difference on an RTI ramp. And with a well tuned set-up, the difference in handling is not even noticeable - even with soft coilover tuning. I have yet to see one person on this forum that has removed the rear SB on a JK and noticed a difference in handling. You do get more axle droop with coilovers or a long-travel set-up and better balanced flex on the trail, but you won't experience this with standard length shocks because the shocks will limit before the sway bar does.
The Wheelin Man's Friend
Like these other guys have said, there are better options and they've all been mentioned here. No one is lying about Rough Country either. Been there done that even when I knew better a couple years ago. LOL Their budget boosts are a deal, but the coil lifts leave some to be desired.
If you're wanting to do it once and not have to mess with it again after adding bumpers and such then stick to a coil lift. You'll get a little extra height over what is advertised but you'll have room to squat with bumpers, winches, passengers, ect as time goes on.
With 2.5" of lift on a JK you can do pretty much anything. There are guys here with the 2.5" Max Travel from Rock Krawler running everything from stock 32s and 33s to 35s and even 37s like I have on mine.
For 35s I think that 2.5" lifts are the way to go. Plenty of added clearance for tires and obstacles, but not so big you have to throw your wife/girlfriend/sister/cousin/midget (JKristie) up into it to go to dinner either.
If you're having trouble searching for info on the forum type what you are looking for into Google and add "JKOwners" to the end of it.
Marcus
I dont have any experience with full traction on my rig, but i have seen plenty of their shit break on the trail (dont get me wrong if ya try hard enough you can break anything but theirs seems to break too easily).Go with a rock krawler 2.5 stock mod, plenty of room for the 35s, no worries about the driveline, and easily upgraded down the road when the funds are there. Plus Jeremy over at RK is a great guy top notch customer service. Good luck with your build.
Sometimes you do at the cost of stability... That also depends on your setup. I ran no swaybars on my Tj for years
Wowa, interesting stuff. I Always thought that the rear sway bar flexed the rear suspensions to it's max articulation, assuming the bump stops wouldnt touch.
^ Nope- a sway bar's job is technically to limit articulation. In most vehicles, it does. In a vehicle designed for any off-road use, you'll have rather long end links, which allow deflection, and reduce the limitation. Usually there is another factor, such as shock length or bump stops, that will limit articulation first. After you address these issues, as desert dog said, the sway bar will limit you.
For on-road use, I'd say leave it on- I disco'ed mine, and I certainly noticed a difference, but I drive my rig like I stole it. More body roll, and a less-responsive rear end (lazy butt syndrome :)). I disconnect it off-road, and it does flex better. Since I still run OEM bump stops, I tend to hit the fenders a bit, but so it goes :) Mark W.
Sounds like you have a flex joint that doesn't want to take grease. It wouldn't be a bad idea to clean them out after all that exposure to salt and sand.
As I said, my issue was BUSHINGS, not joints. The bushings come apart by spring. It's happened a few times now. I had the swaybar disco's and went through 3 sets of bushings before I went to RK's all-metal design. I've also had two of the TF steering dampers, and same thing- Mark W.
Discussion Starter #20 (Edited)
Thanks for all the info guys. The RK stuff looks pretty sweet. A little more cash than I was hoping to spend, but I'm definately considering them. I'm also considering Teraflex, as a have a couple friends that have or have had them and are quite happy. The RC spacer lift is inviting mainly because of the price. If anyone else has anything to add, or suggestions please feel free.
1 - 20 of 36 Posts
