Just did a full overhaul of my 2013 JKU stereo this past weekend so I have the following up for sale:
430N Head Unit, excellent condition, no scratches, works perfect: $600
Nav-TV ALLGIG-XG HS (w/ AV Input Harness). CLICK LINK FOR SPECS I shortened the wires of the ones not being used as I just wanted the back up camera at the time but this thing does quite a bit: $200
PAC C2A-CHY23 Add and Amplifier Interface: $50
Arc Audio XDi805 5 Channel Amplifier with remote knob (was flushed into the center console above the e-brake hence the appearance): $125
Specifications:
Power Output @ 4 Ohms:
4 x 80 Watts
1 x 240 Watts
Power Output @ 2 Ohms:
4 x 120 Watts
1 x 400 Watts
Bass Boost: [email protected] 45Hz
Crossover (Butterworth):
HP (50Hz - 250Hz)
LP (50Hz - 250Hz)
Remote Bass Boost: Yes
Fuse: 3 x 30 Amp
Size: 11.25" L x 6.5" W x 2.25" H
Image Dynamics IDQv3 10" with down firing enclosure: $125
Specification:
RE: .9/3.6 Ohms
FS: 26Hz
QES: .437
QMS: 2.806
QTS: .374
VAS: 3.0 cuft
Xmax: 18 mm
SD: 519.45 cm2
SPL: 87.22 dB
Recommended Enclosure Size (sealed box): 0.65-1.0 Cu.ft
Mounting Depth: 5.8"
Mounting Diameter: 11"
Power Handling: 50-750 Watts RMS
XMax: 17.0mm
Sealed ft3: 0.90
Ported ft3: 1.50
All items are located in San Diego, CA and I will be more than happy to ship anywhere on your dime.
Thanks for looking!
have to ask maybe the obvious question.....assuming this is wrong can-bus speed to be used in a 2010?
it is very annoying to not have bluetooth music support in the old style.
