1 - 12 of 12 Posts
Selling an easy axle upgrade package for someone.
Use parts from your current axles and purchase axle shafts.
OEM locker/swaybar wiring harness (complete harness)
Front CV Driveshaft complete with t-case and axle housing yokes
Front DANA 44
Rock slide engineering outer sleeve kit
top and bottom knuckle gussets
Gusseted upper control arm mount
EVO front control arm skids
Poly Performance front track bar bracket
Set up for Hydro Assist steering
Poly Performance ball joints (full set)
Alloy USA axle tube seals
OEM Rear Locker (32 spline)
4.88 gears (professionally installed)
HD Teraflex differential cover
No outer knuckles
No Brakes
No axle shafts, you will need 32 spline inner/outer shafts from either Ten Factory or RCV
Rear DANA 44
OEM Rear Locker
OEM Axle shafts
Teraflex rear track bar bracket
No Rear Brakes
$3000 meet up or pick up or $3400 shipped CONUS.
Located in Provo, UT, but travel quite a bit over the west.
Shipping to 32259?
Is that front shaft a OEM shaft? Or aftermarket?
How much for the front shaft and yolks?
Discussion Starter #12
I'll do everything for $3400 shipped anywhere CONUS. I'm not sure what company would ship as I had the freight guy at work get me a quote. We do a lot of freight, so we get great discounts.
I'd rather not split up the shaft and yokes, because the axle side yoke is setup already.
1 - 12 of 12 Posts
