21 - 40 of 48 Posts
· Registered
Discussion Starter · #22 ·
lol thanks goody :D
now... what are my options?
1. tackweld the cap on there? I drove 60 miles like that last night to get home... I got a feeling the u joint is toast.
2. replace u-joint all together using Doc's youtube tutorial (btw ty)
3. throw in some new axle shafts...
what other options do I got?
a few questions. could I have damaged anything inside the differential from driving with the cap off like that?
is it safe to drive low speeds to a buddy's garage? one of you local guys will have my rig parked outside soon. :D
· Registered
lol thanks goody :D
If it was me I would pull the shaft and stuff a rag in the tube depending on how far you got to go. the ears on the shafts may still be good.
If so Id slap in a new u-joint and call it a day.
· Registered
Discussion Starter · #29 ·
The ear is the hole in the shaft where the u-joint is located. If the ears are stretched, the u-joint will not seat correctly in the hole and the shaft will have to be replaced.
im talking about the ears where the U joint sits. if they not wallered out.
thanks guys. sounds like i should take the axle shaft out to have a look before i buy anything then.
· Registered
i gotcha. hmm. sounds like i should take the axle shafts out to have a look before i buy anything then.
I'd agree on them probably being wallowed out. Check out 2012+ Dana 30 axles, they use the Dana 44 u-joint...as do Nitro chromos.
· Premium Member
Holy f**k lol
· Premium Member
RCV's woohooo
· Registered
would this work for a 10' with sleeves already?
all i need would be a driver side axle shaft lol...
Yes it'll work. Depending on who's sleeves you may need to trim them a tad, I think the earlier EVos stuck out quite a bit. The axle shaft is no larger OD, just the larger U-joint is used at the end.
I'm just saying if you plan on wheelin' that D30 and need to replace a shaft, going to the D44 joint is a pretty worth-while upgrade.
· Registered
i like the idea of a axle shaft blowing up verses my arb and spider gears. hopefully i can find one of those 12+ with a driver side axle shaft
Or those tiny ass teeth on your ring and pinion :) I feel you dude. I have a 30 with 5.13s. About to add an ARB I got from MrRonGilbert :gluging:
I doubt youll ever break the ARB.
· Registered
Discussion Starter · #39 ·
ya. i dont wheel that hard at all. not even frequent either. once a month.
perhaps i'll pull the shaft and verify the ears are ok and replace the ujoint. if broken, than i'll go ahead and swap the axle shaft if available. if not then i'll go with rcvs.
21 - 40 of 48 Posts
