I got a 2010 with 513's and ARB Lockers in front and rear. I recently been hearing what sounds like a low speed clanking noise. The noise isn't audible of speeds over 40MPH. It's really noticeable at under 20MPH and I can hear it going slow. At higher speeds, there are no aduible hums from the drivetrain or vibrations. Other than the tire noises, everything seems to be just fine. Four Wheel low works and clanks, four wheel high clanks, and in two wheel drive it clanks at the speeds mentioned above.
It's coming from the front differential. When I stopped it yesterday and put it into park, I could turn the drive shaft a full 45-90 degrees and hear something clank in the front differential. I'll be pulling the differential cover today just to have a peak inside.
I've searched for a few hours while it warms up here, I've seen some mention about pinion bearings being loose or about to fail... Backlash not being set right and it being an issue...
These gears have about 10K on them and never made a single noise.
Can anyone shed some light on what issues may be ahead?
