I was recently rear ended and pushed into another car, my lower cross member is bent back a hair, should i straighten it before installing the skid or will it not make a difference.
Btw, i was at a standstill and some goober wailed into me at about 35 mph, the JK looked like nothing happened, the other 2 cars were mangled pretty good :thefinger:
Sounds as if the crossmember is bent that the frame may be "tweaked" as well. I wouldn't do a thing until you find out what the a$$hats insurance company is going to do. I know you need to go through your ins co initially, but I don't think I would be doing anything to fix it w/o finding out where/ when your help (money from the insurance) is going to come from. Sure doesn't sound like it was your fault. JMO
Hope you are OK.
Discussion Starter · #3 ·
the problem is that it was already repaired and then i found that was not repaired, its a long story. Im about to kill the body shop that fixed it. the tabs that the cross member is welded to is bent by about 1/4 inch
