Long story short I replaced a ujoint with a moog cross joint that had life time warranty. I wanted spicer but nothing readily available so I decided on the moog thinking once that wears out I can get a better joint. Maybe that moog joint will prove to be great?
Well it wasn't great. It was the poorest 50$ I have ever spent. The cross joint cracked and fell out on the highway. The ears on on the shaft are now malformed and missing material. Just can't replace with a ujoint. So I need an axle shaft passenger side. Also the stub shaft is seized to the hub assembly.
My shopping list is
Hub assembly
Passenger shaft assembly
Or
Rcv shafts
Hub assembly
What hub would you recommend?
Would you recommend rcv's
Should I just get a new shaft assembly?
Thanks!
My shopping list is
Hub assembly
Or
Rcv shafts
Hub assembly
Thanks!
