Do you really need the PP track bar bracket to install the Fox Jeep JK Steering Dampener? Or can I run the stock brackets for now?
This is what I use...tucks the Fox out of the way...Wood's steering stabilizer relocation bracket....Do you really need the PP track bar bracket to install the Fox Jeep JK Steering Dampener? Or can I run the stock brackets for now?
Yup. Got Woods version 1.1 on my JK already. Cool. Ordering stabilizer now... :grinpimp:The only potential issue I see is that you will have to flip the stabilizer around, as the body of the skinny stock one fits pretty tight in the axle end. But I don't see any reason otherwise.
Yes, the Woods relo bracket does this... I think I might upgrade to the new 2.0 version. Although looking at your photo, I don't think the FOX stabilizer will work with the Full Traction track bar... gonna have to do some measuring.I run the Poly track bar bracket now, but when I first had the the Fox dampener I made a bracket, real easy to do.
Due to the length of the Fox dampener you really need to relocate it above the tie rod.
