I have a 2008 JK Unlimited. My fog lights have quit working. Has anyone else had this issue? The fog light indicator Also does not light up on the dash. Any thoughts on troubleshooting this issue.
Could be a couple different issues. I would start by checking your fuse. Since your fog light indicator isn't coming on it could also be the switch in the turn signal that either has a loose connection or has gone bad. I know this was an issue on the TJ's.
May want to check your connectors at the lights as well as the c300 connector (large connector near radiator on pass side). Check wiring down there, they usually get covered in dirt / grime. Next I'd recommend verifying all your TIPM connectors are pushed in firmly. After that, maybe check continuity / voltage on the switch. Could try disconnecting battery for a minute or so to jog the tipm.
