1 - 15 of 15 Posts
OK I am a total rookie when it comes to electrical. I have been all through this site and think I understand what I need.
I have Hella 55W lights I put on the bumper
They turn on then off but will not stay on
I figure I need to "replace" the factory relay? Or do I need to install one all together?
I looked in the owners manual and can not find where the fogs hook up to in the engine bay. I.E. does a factory relay exist? which fuse are they connected to? Is anything else on that fuse and relay?
Thanks!
I am looking for the actual physical location of the factory relay and fuse. It is not listed in the owners manual or the cover of the fuse box.
If the answer is yes, I can replace the factory relay with a new one in the same spot that is what I want to do.
Since it is not listed in the owners manual I was also trying to figure out if it is the only thing on that relay and fuse.
It is almost always a bad idea to just bump up the size of a fuse and replace a relay. The fuse protects the wiring, not the lights. If you pull too much current through the wires, they can (and will) burn up, as in fire under the dash.
It takes about an hour to splice in to the factory wiring right at the bumper and put a relay in there, then run a fused wire from the battery to the relay to power the lights. You could spend another 30 minutes and put a connector on your wiring so that it just plugs in where one the old fog light bulbs were. Connectors are cheap on the internet and this way you aren't even crimping splices into any factory wiring.
Bryan.
Just install another relay triggered by the factory circuit. Only takes a few minutes and works fine.
Tyra. Do this ^^^
That's how my fogs are wired. Works perfectly and you don't have to worry about messing with the factory relays.:)
The problem is if I wire the whole thing I am good or if I am replacing one for one but I don't know where to input the relay. IE physically.
What can I use of the factory stuff, anything? Can I wire them to the wire harness up front put a relay somewhere in the system and still use the factory switch? Other then knowing the switch is on the steering wheel and the hookups are up front that is all I know of the factory wiring.
If not, I can wire the whole thing in with all new stuff I was just trying to avoid a new on off switch for fog lights.
Discussion Starter #10
Should I add for those of you who don't know, I am a woman and when it comes to electrical I guess I need it spelled out LOL I know high maintenance. :thefinger::beer::beer:
Use the diagram in post 3, connect terminal 85 of the relay to the + of the factory fog wiring. Ignore everything in the diagram connected to terminal 85, but do all the rest.
LOL Call me. Good one. I'll see your call me and up you a come to Florida and I will do it for you!
Seriously, all you have to do is cut the factory wiring around the plugs (leave some wire incase you want to go backwards one day), add a relay from autozone, run a fused wire to the battery and your golden. I have 2 4" HIDx driving lights installed into my Overkill bumper and this is how I have them wired. That way you can still use your factory switch. Again see the diagram I put up and do what Phil said. He's a smart man!
Discussion Starter #14
OK Got it! Thanks Co4Lo I went the Call route and a little hand holding through the phone gave me what I needed :D what Phil said is what I got out of it.
:thefinger:
1 - 15 of 15 Posts
