1 - 8 of 8 Posts
I need to run a cable through the firewall. I found the huge rubber grommet on the passanger side but it's a pain to get to and I don't think I can run another cable in there. I read somewhere about a foam seal that you can run a cable through on the passager side where the dash meets the frame. I took of that cover and put a screwdriver through the hole but I can't figure out where it goes. What do I do?
Stick a wire hanger through it so you can see where it comes out..
x2 on the coat hanger. Run it through the foam insulation, tape the end of the cable to it and pull it back.
I did not see what year jeep. On my 12 there is a pass through right by the brake booster.
Ok so that circular rubber piece is a pass through? I was worried about cutting into it because I didnt know what it was for! AHHH!!! now to find a switch bar that is easy to install :p
1 - 8 of 8 Posts
