1 - 1 of 1 Posts
Morris 4x4 Center is now a proud retailer of Firestik antennas!
Welcome to the most popular wire-wound CB antenna in the world! This is an original FireStik design and a proven performer since 1975. "KW" antennas are compatible with autos, trucks, vans, motorcycles and ATV's in a single antenna configuration when metallic ground plane is available.
The 3/8"-24 thread fits all FireStik mounts and CB radios. Simply screw the antenna in the mount and it is ready for use after tuning. The 3/8"-24 threaded base has a tapered contact point that works especially well with FireStik mounts and accessories. The tapered "lug-nut" effect transfers stress away from the threads and reduces the possibility of vibration induced loosening of the antenna in its mount. Each antenna is covered with a static reducing, water-tight sleeve containing UV and pigment stabilizers. For peak performance we recommend that you use one of their 18-foot Fire-Flex coaxial cables with these antennas.
These Antennas are available in (4) colors. Black or White with a red tip, or Red or Blue with a white tip.
Also available in both 4' and 5'.
(100% American made with 100% American materials)
Get yourself a Firestik!
1 - 1 of 1 Posts
