1 - 20 of 56 Posts
Hey everyone I'm new to this site so if this has been reviewed I apologize in advance. I am currently looking at the EVO mfg. 3 inch double down long arm lift kit for my 14 jk 2 door. Is anyone running this kit or seen this kit used in person and if so what is your thoughts or opinions. Thank you
It's an alright kit and kinda pricey for what it is. IMO they set it up with too little up travel in the system. If you do any real high speed off road you will be constantly hitting your bumps. To make it work like it should you should be more at a height of 5" of lift and run higher coil rates. This will give your shocks the room to work and not just ride along in the bump zone of the bypass shocks, but will also make the on road ride stiff and jarring. If you are not doing high speed dessert running you are just wasting your money on the double throw down. You should also spend some time with someone that knows what they are doing to do some tuning and dial in the shocks. I have done some tuning on the kit that was installed by EVO and the owner could not believe how much better it rode after tuning. Most people that buy this kit have no idea what they are doing when it comes to setting up coil overs and bypasses and just run it for looks.
I just finished installing the double throwdown, lever and high clearance arms. It is very involved, not very good instructions and I would say that just cycling the components through their movements there seems to be a lot of binding and running bushings to their limits.
Initial thoughts with driving it:
Ride quality is ok out of the box, better than the cheap lift that I took off the Jeep. I will be spending time with a suspension tuner once I get the other bugs worked out.
I was very disappointed with the toy bypass shocks that come with the lever. I now know there is a 2.5 upgrade available. I’ll give these a shot, but believe I will be changing them out once I get a little tuning done.
I’m going to have to change springs at least in the rear. If I run any preload whatsoever the rear end will have about 8” of up travel and sit too high.
The suspension acts very funny when trying to brake torque. It doesn’t stay flat at all.
At this point if I were to do it over again, I would probably not use EVO. I was looking for the best kit I could put on myself without getting into trial and error learning of custom suspension. Not sure who I would go with, but I feel that too many sacrifices are built into this suspension due to working around a lot of stock limitations (axles, track bars, fuel tank).
Time will tell if my opinion changes. Like I said I am still working out bugs. I made a lot of changes at once. L86/8L90/Atlas Dana 60’s DTD, Lever, long arms, 40’s, hydro assist.
Thank you guys for the input. It helps. I wasnt planning on running the coil over system, they offer a standard coil system also. I am currently running the Teraflex 2.5 basic spring lift with the vss shocks. I want to upgrade to a long arm system and was just looking at different options. I want to keep the center of gravity low.
I have ran the regular EVO long arm kit and now I have the high clearance long arm kit. Do I like it? Yeah it does fine for what I do. Is it the best setup out there? Probably not. I have not been in a Jeep with other long arm setups. For drivability you wouldn't go with the high clearance kit as it puts the rear arms at a steeper angle. I did the high clearance on my second JK because I didn't want the brackets hanging lower than the frame; I wanted the clearance to help get over ledges and big rocks. I run coils. I ran the EVO plush rides with Bilstein 5100s for a long time. I now run king shocks with the evo springs in front and metalcloak in the rear. My rear evo springs were sagging so I got metalcloak recently. But to answer your question, yes it's a good kit, quality arms and joints, and you should like the ride on road and it will do great offroad. Good luck sir.
IF you are looking at the lever, it has a massive amount of rear steer. We measured like 10" of axle shift with that kit that we installed.
I just got done re-doing a standard EVO coil over kit and reused the shocks. We kept the front bolt on but did a double triangulated rear and did a fusion 4x4 ton swap at the same time. I would not recommend the EVO coil over kit as the rear uses an 11" travel shock if you think you may do something different in the future. I would also look at Accutune as they have a good coil over kit and they do custom tunes for your rig not the generic tune EVO does for every JK.
Where are you located at? Also with you wanting a LCOG build what tire size are y ou planning on running?
The lever is only a shock/spring replacement and will have no affect on the axle placement other than up/down. What arms were used when you measured that 10” of axle shift?
I think I will ultimately end up ditching the high clearance long arms for something that has better attitude, but I want to spend some time tuning it before I move on to that step.
Thedirtman I plan on sticking with 35's for now since i still have the stock Dana 30 and the crappy 3.21 gears. I do hope to upgrade this in the near future but they work for now. As for the type of trails I do I dont think coil overs will be necessary.
Discussion Starter #10
Redrock I appreciate the input after some of the reviews I've read i may be looking toward Rock Crawler or just sticking with Teraflex and doing their Long arm upgrade since I am already running their springs
You read a lot of hype about them. They really push the marketing on the forums and social media. In truth their products over the years have had many issues and redesigns. They push that their kits are upgradeable, which any lit is but people think it is something special. Their kits are overly heavy and add more weight than other comparable kits. From the kits I have installed the fit and finish of RK is sub par and the off road ride in RK equipped JK's is jarring. I have installed just about every brand of lift kit out there and can tell you RK is a lower end kit with a high end marketing program and price.
Discussion Starter #14
So if you had to choose a 2.5 - 3inch long arm Kit with coil springs for moderate wheeling and a daily driver what do you suggest?
Personally the only long arm kit out there that is worth a shit is the Genright and it is stupid expensive. You are not going to see much gain at all by doing a long arm kit that is offered today because there are too many limitations on the JK without hacking it up and moving the fuel tank on the rear and up front most kits are only a couple inches longer the the factory arms. IF you want a great set up for a daily driver and wheeling look at Metal Cloak or Synergy, they both have options in your lift height and use a good joint that gives superior ride quality vs the ball and socket type. If you don't like those then I would look into genright, EVO, Currie, Clayton, JKS. Learn what's in a lift kit and what you need for the height and tire size you are looking at.
Discussion Starter #17
Thank you. I appreciate the input. You have been very helpful
I will second dirtman on metalcloak. When anybody asks me about lifts for their jk I steer them to a metalcloak game changer rocksport version. Its a 100% bolt on suspension that anybody can install in their driveway without any drama. While I am happy with my rockkrawlerish 3 link long arm (I use their frame side mounts), the metalcloak kit would have gotten me 90% there.
Hows the geometry design of the Synergy or Metalcloak long arm kit compare to other brands?
Ive always been a big fan of Synergy products.
Not great. The metal cloak is a radius front set up and the synergy hangs the lower rear brackets off the bottom of the frame. It'd tough to do with everything that is in the way on the JK.
1 - 20 of 56 Posts
