Ok it's happened at least 2 times since I put on the 35" tires a week ago. Usually on a offramp if it is bumpy and uphill. Pain it the arse and the only thing out of alignmnet is the caster which is +2.5 degrees. Dealer does not believe it's a bad sensor even thou it happened when parked when I had 33" tires.
What has everyone else found on this issue. I guess I can run a switch to perm disable it.
