1 - 12 of 12 Posts
So I've searched on here and googled online and while I find some ESC light related articles I am not seeing my exact problem/issue and I guess I am hoping someone here can fill me in on how the ESC works and confirm what I am thinking or confirm I am thinking about this incorrectly.
So this past week, we took a long road trip and both coming and going encountered strong crosswinds, both times causing me to "countersteer" to the left to get my jeep to track straight down the highway. While doing this, with the cruise control on and running highway speeds of 70-75 mph, the ESC light would flash on and kick the CC off. As long as that light stayed on the CC functions were locked up and cruise would not work or function in any manner. Each time after I stopped and cycled the ignition switch, the ESC light would go out and CC would work fine again. Once I got out of the strong crosswinds everything has worked fine as well.
I had an alignment done about 2 weeks ago and jeep drives and handles great otherwise. Steering wheel does seem to be a hair off-center to the left as well (but not much at all), I will adjust this tonight. But other than counter-steering in those cross winds I have had no issues.
So my understanding is that ESC reads "wheel speed" and "steering angle". Would the "steering angle" from counter steering in a strong crosswind (like a 1/4 turn of the wheel) be so sensitive as to cause this?
Specs are: 2017 JKU on 37's that has been re-geared and tuner used to reset gear ratio and speedo, 3.6L with an auto transmission
Thanks in advance for your feedback.
Gunnery Sergeant USMC (ret)
Simple answer, YEP.
You ever think about doing the switch to kill the ESP?
last Friday my esp light blinked a couple of times on the way but I know that my steering wheel is off 1/8. but not my daily so it stays.
Only problem with disabling the esp is your cruise control won't work. It a built in safety feature. I use my bully dog programmer to clear the code when it comes on.
Sent from my SM-N910V using Tapatalk
as Gunny said; yup.
It doesn’t occur AS MUCH ( still can) if your steering wheel is perfectly centered of course because the slightly uncentered steering wheel is able to exacerbate a wind-sheer quick correction angle & do so abruptly which will set off the slip-traction bells and whistles and safety measures. Center the wheel and only gale force winds should cause this again. The kill switch is whatvmany of us have done ...
since they are so soccer-Mom adept , the four door JKs in particular will ride so well down the freeway at speed that it’s quite easy to get yourself to forget that, in essence, your driving something 75-80mph that’s as aerodynamic as your office trashcan so, yeah...wind shear susceptible doesn’t ever fully go away, heh :jeep2:
The funny thing is I switched the ESC Off button thinking this would overide it, but even with that turned off (like it does when you put it in 4 LO) the ESC light still came on and kicked the cruise out. That just seemed odd to me that it would still "work" even if it was manually turned off.
I did re-center the steering last night so I'll see what it does down the road. Since it was isolated to this trip its not been a problem up until now so I'll just play it by ear. Thanks for all the feedback.
thats not how it works ; disabling via that button does not completely disable all of the anti-skid functions .
:jeep2:
:jeep2:
Agree....that is why I did my mod to bypass everything
Well I do get that now, but logically it made no sense to me at the time. :laugh:
Not a lot of the Jeep nanny shit makes sense, or is well executed. We've all heard the stories of someone taking an offramp a little too fast and the Jeep will try to send them off the road to "save" them.
I've had gusts of wind kick off the cruise many times and my steering wheel has always been perfectly straight.
1 - 12 of 12 Posts
