Two times now I've gotten the error code PO369, bank 1, sensor 2.
Both times I was going about 70mph when it came up.
There are 2 camshaft sensors on the engine. Does anyone know which camshaft sensor bank 1, sensor 2 is?
It is the sensor on the back of the passenger side cylinder head, pointing almost straight up.
Not as simple as just changing it though... you need to do a"synch" or "relearn" process on a capable scanner.
Sometimes that code is a symptom of other problems also. For me it was the wiring to the sensor, and the connector.
Mine was also throwing another code that would light up the traction control light and put it in limp mode, but only part of the time.
Fixing the cam sensor fixed that also...
As mentioned, there are two camshaft sensors. Each sensor monitors two camshafts. Each sensor has four circuits in it.
The code P0369 means there is a problem with the circuit on the intake cam side of the sensor, on the passenger's side of the engine.
Being intermittent suggests there is a bad wire or a loose connector.
