I just traded my 2015 JK 2 door for a 2016 JKU which is used with 8,000 miles. There's is really fast vibration at idle and worse when you put it in gear. It's an automatic. Really noticeable when you pull up to a stop sign or light. It almost feels like a harmonic balancer or maybe trans flex-plate. Not at all like a dead spark plug or a bad valve.
It is still under factory warranty and will be going in to have it checked out, but would like to hear if anyone else has had this issue and what was the outcome? The 2015 I traded was smooth as glass.
Thank you in advance.
welcome & take some time to introduce yourself in the Welcome Room when you've time later on ...
Have you opened hood and had someone drive it a few feet, come to an idling stop and viewed the engine bay to verify there's not any engine mount issue or anything ? I am fairly sure the newer models don't have harmonic balancer son them like earlier JKUs did on xfer case but maybe you mean on tranny . There was another recent thread about a 2016 4 door that was going back to dealership with a improperly machined flexplate or housing mating surface and couldn't seal but your issue sounds different . What happens under load ? Like, when you are idling , in gear but use left foot to hard depress the brake as you slowly bring on the accelerator ? Sounds very much like something with the torque converter from your description .
I've not heard this before . I'd have that back at dealership if brand new deal and get in another JKU or I'd sick my wife on them. :wink2:
Good luck and let us know wtf it was
Somebody asked me to introduce myself. I'm Bob Albright, Joplin, Mo. I'm a 65 year old retired 18-wheeler parts counter man/outside sales. This is our 4th Wrangler. 87' was the first, 05' was next, followed by a brand new 15'. All were 2-door models. We finally decided to get a JKU. We found this one with only 7,187 miles on it. Grandkids getting too big for the 2-door models.
Now for the vibration. I was referring to older model engines that used a harmonic balancer (vibration dampener). This vibration does feel like that when the balancer's went bad or was hit. I believe it's either the torque converter or flexplate. It's most noticeable when in drive. Yes, I have put it in Drive, holding the brake and accelerating slightly. It'll vibrate enough to distort the image in the mirrors. Also really noticeable when cruising city streets, say around 30-35 and the trans goes top gear and torque converter locks in. But, it is noticeable when just setting in neutral, which could be the flexplate. Same thing as a flywheel, it's spinning because it's directly connected to the crank.
That 2015 JK Sport we traded off ran so smooth. Sometimes I glanced at the tach just to make sure it hadn't died. I would love to hear more about this improperly machined flexplate thing. Now I wonder.
Thanks to all for helping the "old man" out. Love the new JKU, just don't like the shake.😆😆😆
