Engine harness troubles
1136 Views 1 Reply 1 Participant Last post by  dgraves.srt
Since February my 2008 jkux manual has melted 5 coil packs and thrown a multitude of codes, first time I assumed the system was old and just replaced the whole set up plugs wires coil pack, note coil pack was Mopar and I used ngk plugs and wires.... Pack 2 I installed improperly and broke it before it ran once then when I did run it it grounded through the crack I made and melted it.... Pack 3 lasted about a month then melted so I went through all the grounds and what not, pack 4 and 5 melted the same day over a 15 mile distance..... At this point the ground is good the only issue I've seen so far is the harness has some weird stuff going on. If you track the br/wt wire back to the PCM it goes to both circuit 1 and 2 so I decided to test for ohms resistance from the coil pack connector to the PCM side and noticed 4 of the wires on the orange PCM connector are reading at 12ohms compared to the black one at .8 ohms.....
I guess my question is what are those wires supposed to be and if they are not supposed to have resistance can I splice them together somewhere other then on the firewall behind the intake..... Any help is appreciated the circuit I'm specifically dealing with is based around splice s121
Font Material property Parallel Rectangle Number
Rectangle Line Font Parallel Pattern
Rectangle Slope Line Font Parallel
1 - 2 of 2 Posts
Update I found better diagrams and sorted out the 12 ohm issue that was my injectors, I’ve narrowed it down to coil 2 failure so I’m thinking possibly a pcm, not sure where to go from here… maybe throw In an inline fuse and see if that saves the pack for further testing…..
1 - 2 of 2 Posts
