1 - 11 of 11 Posts
I have a jeep liberty sport 2002
when i start it in morning it will run forever but when i shut it off it wont start unless i leave it set for a while. I changed the starter, the relays the battery and terminals the charging system was also checked i cant figure out whats wrong been trying for 7 months no check engine light on and no codes showing up if any one could help it would be greatly appreciated i am at a loss for what to try next.
electric problem
when i turn the key to the start position nothing happens the lights that come on when the key is on accessory like the oil light abs engine but when you turn to start position they stay on but wont start i think that theres a short or a sensor overheating but im not sure she said her panic button on remote dont work but the door locks do could the alarm or anti theft still be on somehow?
by chance is there a RED LED on the dash when you turn the key to start it (when it doesn't start?)
The reason I ask is; I've read where people are having issues with the security ststem. Apparently it's not recognizing their key and they had to have the dealer reprogram them.
Have you tried your spare key when this happens?
i didnt see one but there may be i will have to check later its not here right now. but if red light is on what would that mean?
i called girlfriend she said that her remote for the alarm only works the door locks the panic button doesnt work could the alarm be sticking on or activating the anti theft ?
the alarm beeps the horn when you turn it on but when you deactivate it the parking lights blink but the horn doesnt beep
thanks i will try to go to the dealer and get a new key
hopefully that will fix it cause sensors get expensive i really appreciate the help i will get back on here and let u know if that works probably monday thanks again
Sorry for not getting back to ya. My computer froze up last night, Ugg!!!
Yeah, the dealer can put it on their diagnostic machine if need be. But if the vehicle isn't recognizing the keys (all of the time) then that could very well be your problem.:beer:
As far as the horn not beeping when you deactivate the alarm...I think that's an option you can program in yourself.
Discussion Starter #11
problem found
the auto shutdown relay was shutting power to the starter ignition and the fuel pump it was triggered by a short in the fuel pump wires i changed the wire to the fuel pump and now it starts fine sorry took so long but i been busy thanx for the help
1 - 11 of 11 Posts
