1 - 2 of 2 Posts
Hey all,
Does anyone worry about water vapour from their electric compressors enough to use a separator.
Building up in a reservoir without a drain valve for example?
Cheers
I always have a drain valve. It is not just what gets in the line, water standing in the tank will cause corrosion. A water filter inline is also a good idea. I was going to put one in my when I rebuilt it but there was no room where I set it up. I will redo it and put the air feed on top so I can put the filter inline. If you are just doing tires it is not as big a deal compared to lockers off the tank.
1 - 2 of 2 Posts
