1 - 13 of 13 Posts
I’m in the process of having new custom axles built for my JK which is why I'm selling the axles listed below.
The axles have approx 6,000 miles (at the most) and are in great condition. Asking price for the Dynatrac Pro Rock 44 and Pro Rock 60 (semi-float) is $6,500.
Prefer local sale, but I’m willing to ship on buyer’s dime.
The front axle is setup for coilovers (no spring perches or factory shock mounts). The lower link mounts are custom. The upper links mounts are OEM Dynatrac. Has synergy hd trackbar bracket. There is also a custom ram assist mount which can be retained or removed.
The rear axle is setup for a triangulated four-link suspension. All current brackets are custom (lower are custom, uppers mount to the Dynatrac bridge). No trackbar bracket. Buyer has the option of retaining these brackets or removing and installing their own brackets as needed.
I can have the factory Dynatrac brackets (or any aftermarket bracket of your choice) installed by a local shop for an added cost. Willing to negotiate on axle price and costs for having these axles converted back to a bolt in application.
Dynatrac Pro Rock 60 (semi-float)
Dana 60 R/P 5.13
ARB 35 spline locker
35 spline axle shafts
Dana 60 Timken master kit
5x5 bolt pattern
Dynatrac diff cover
JK PR44 front housing unlimited (1/2” tubes)
Synergy ball joints
5.13 high performance Yukon ring and pinion gear set
Master overhaul kit with Timken bearings
30 spline ARB locker
RCV axle shafts
5x5 bolt pattern
Reid Racing knuckles
Synergy HD trackbar bracket
Custom ram assist mount
Dynatrac diff cover
Located in Sacramento, CA area
Price: $6,500 (paid just over 11K new)
Availability: likely not until late May. My custom axles are still being built and will likely not arrive until early May. I've chosen an installer but cannot confirm an install date until I have my axles.
PM me if you have questions or I will try and respond to the thread when time permits.
If you are in need of a set of axles, these might be for you - top quality and a great price.
thanks
Update on axles sale: I have a committed buyer for these axles. Deal will be completed end of May when axles are removed. If for some reason the deal should fall through, I will update this thread accordingly.
gosh, what a cleanly built JK and suspension/steering. Superb.
@RustyNail ,I have seen those trailing arms someplace before and I wanna say Savvy but cannot be sure.
Please, OP; it'd be cool to know what arms those are on rear lower!.
I would love to buy these axles from ya but I am 6-10 months out from beginning axle shopping....someone will buy these and get much use from them....
<edit: oops. I didn't see you'd already acknowledged that the links are custom. Maybe they were in a magazine or another thread because I have seen those trailing links that have the "S" logo on them previously and for the life of me I cannot recall where. It may have been this Jeep/forum!
Ah, age is a wonderful thing...>
Thanks! I'm running Mike Shaffer's (Shaffer's Offroad) Exile Suspension - Red Label System. Here is a link to a thread we had posted a while back. http://www.jkowners.com/forum/modified-jk-tech-dept/215954-exile-suspension-red-label-system.html . Mike has since evolved the exile performance line and I plan to re-visit his shop this winter for his new line of trailing arms.
Things did not work out for the committed buyer. The axles remain available for sale and need a good home. :grin2: Price is $6,500 for the two axles.
Also, I have a TF BBK, synergy tie rod and synergy draglink which will also become available once my axles are removed.
Thanks.
Discussion Starter #9 (Edited)
Update: I have a new committed buyer for these axles. Deal will be completed mid-June. If for some reason the deal should fall through, I will update this thread accordingly. EDIT: the new buyer I have lined up also purchased the big brake kit.
Discussion Starter #11
I appreciate the update. I would like the option to buy the rear definitely.
Got it. If the new buyer ends up not buying the axles, I will update the post and perhaps we can work a deal for just the rear. Currently, I consider the axles sold via a verbal agreement. And the deal will not be officially completed until mid-June.
I'll commit to buying both, update me via pm
If the current agreement falls through and jeep2007 claims the rear 60, I would be interested in the front 44.
1 - 13 of 13 Posts
