Just upgraded from stock Rubi 32 inch tires to the duratrac's 315 70 17 and I was wondering what tire pressure others are running? When the tires were installed they put em at 35psi but the tires feel a bit washy. Should I be running a higher pressure or is this feeling just because I am running a lot bigger tire than I am use to?
Thanks,
Chris
I'm running 28 psi. 23K miles and they look great
Thanks I am going to try the chalk line when I cut my fenders at the end of the week. I was curious to see what psi others are running. At 35psi it just felt like it was all over the road and I was wondering if it was from being over inflated or under inflated.
Thanks,
Chris
I am going to play around with different tire pressures this weekend and try the chalk line. Hopefully I can find the sweet spot. Thanks for the help
Chris
