I know this problem has been posted in the past but i have not seen a solution. My drivers side rear running light is not working. every thing else works fine.
Gunnery Sergeant USMC (ret)
Not being a dick but did you check to make sure it did not come unplugged?
Check the bulb, it's a dual filament job. The driving light can burn out while the brake/turn higher intensity light still works. Also check your trailer wiring harness if you have one. Mine shorted out the driver taillight from corrosion.
