1 - 20 of 21 Posts
Just throwing this out there......I have an 07 auto with 68k. I replaced the driver side manifold and put on an MBRP exhaust with about 40k. I started smelling an exhaust smell in cab about a month ago and while changing fluids, I decided to check exhaust for possible leaks or loose clamps. Well it's the damn driver side manifold cracked again. I am wondering if the Rusty's CAI has anything to do with it. I'm not a mechanic so what do you guys think? Anyone else having repeated manifold issues using a CAI?
Iv'e been hearing an exhaust leak in that area for a long time, I guess its most likely that same thing. Other than hearing the exhaust leak am I losing that much power or mpg leaving it as is?
Your power and MPG will be affected for sure. How much depends on how bad the crack is. The problem with the crack is it allows fresh air to be sucked into the manifold and then the 02 sensor picks up on this and sees a lean condition. The ECU then tries to compensate for the lean condition by adding more fuel. So you end up running rich which reduces power and decreases MPG's.
Has anyone attempted to wrap the manifold with heat wrap when they replace it to see if it helps? My theory on these manifolds is that they heat and cool too rapidly. Applying heat wrap to the manifolds would help them cool slowly and possibly reduce the chance of them cracking.
I have replaced driver's side manifold also. I do believe water from the street or trail is causing them to crack. JK manifold design or quality??????Not sure if wrapping them would do much to prevent the cracks if rapid cooling from water is the culprit.
Well I guess I will be ordering a new one, where is the best price? Is it usually only the driver side?
It could help by not allowing the water to actually spash onto the metal surface and instantly cool it. I have to replace mine (again) So I will give it a shot. It can't hurt any.
Are there any worthwhile gains to be had going with a gibson header or something other than stock replacement?
From what I've researched it looks like most of the shorty headers do not give you much if any gains. I know the RIPP longtubes are popular and do make proven power but they are also very expensive. But even if the shorties give you zero gains it may be almost worth it for the fact that they won't crack again.
So what are the descent options available? It looks like factory headers from mopardirect are $100 per side not including gaskets where as the gibson headers can be had for $300ish a pair with gaskets. I'm ok with spending an extra $100 knowing that it will most likely not crack again in the near future.
If someone running the Gibsons could chime in it would be appreciated.
Breaker of nice things
I had the same issue & went with the JBA titanium ceramic shorty headers. Now, they've been fine for a replacement, but don't think that you're going to get much for gains with shorty headers. If you really want to get your money's worth, then just bite the bullet and go with a set of RIPP long-tubes.
Wish I had done that the first time around. :suicide:
I know, I have been looking at the long tube header for awhile but damn that is a lot of money. Some actual performance gains for the 3.8 would be nice though. I'm planning on a Ripp down the road so I guess it is a viable option.
I can't believe I never thought of the exhaust wrap. I've wrapped the pipes on my bikes for years. It makes sense to me that it could reduce the chance for cracking.
I think the only downside to the wrap would be if you lived in a very wet climate or forged water a lot. I've heard the wrap can trap moisture and rust the manifolds pretty quick. I don't have to worry about that here int he desert but just something to think about. But still it has to be better than a manifold that needs replaced every oil change :suicide:
Quadratec has them for $75 http://www.quadratec.com/jeep-replacement-parts/jeep-exhaust/jk-exhaust.php and I think I've seen them as low as $60 before.
I've replaced my drivers side last year. Now I hear some suspicious sounds from the pass side.:mad: Gonna replace this fall with some after market shorty headers.
for those of us that bought them at the right time, the exhaust manifolds are covered under the lifetime powertrain warranty!
Discussion Starter #20
Driver side exhaust manifold
Well I've been doing research if thats what you want to call it and I keep getting that about all you can do is keep replacing with an OEM manifold. A lot of you serious jeepers know my cousin that goes by ROOSTER on the forum and he had the shorty headers and felt he had a decrease in horsepower. They just don't do much for the terd of an engine like the 3.8 and they are suspectible because of placement to burning sparkplug wires. So cost wise I guess it just as easy to stay with the OEM for the price. Another friend told me to check into getting the ceramic coated, I haven't checked into that yet but sounds expensive for a $75 pot metal manifold. Anyway thanks for the feed back and if any one finds a good deal on an OEM post up the website......DJLAYNE
1 - 20 of 21 Posts
