1 - 2 of 2 Posts
I've searched and didn't find what I needed. So hopefully yall can help me out. I have a 07 Jku and when I open any of the doors the dome lights come on just as they should and the rear dome light works as it should. So my problem is when I try to turn the dome lights on with the switch they won't come on. So is it the switch bad?
It sounds like it could be. In my '08 JKU, they come on with the doors, the rear one can be switched by pressing it, or both by manually turning the collar on the stalk all the way around.
If yours has stopped working from the stalk, it is likely the switch, (as a moving part), but may be wiring or connector instead.
1 - 2 of 2 Posts
