1 - 13 of 13 Posts
Been wondering what these two things are.
The green one is a button switch which when held down will turn on/off what ever it controls with an associated green light. It also has two small contacts and looks like an attachment can be hooked up.
I think the other one is the diagnostic plug, but I thought those were usually hidden more.
Sorry for the crappy pic
Thanks for any info!
The black one is the OBDII port. That other thing is aftermarket. You have anything aftermarket installed? Remote start maybe? That could be a valet switch.
See if you can follow those two wires.
I figured the one is the diagnostic.
As for following wires, I did but they disappear beyond where I can follow them.
I bought it used. Its previous life was an RV tow behind.
Mine had some dealy on it from the factory which was some dealer pre-alarm install kit or something. Had them remove it when I took it in for warranty the first time.
pre-alarm? did it look like the one in my pic?
Another alarm would really help me out, being that I don't lock it and leave the keys under the seat so I don't have to carry them in my pocket!
Not identical but in the same location. It was some dealer installed option that you could pay extra for and they would activate it and give you fobs.
They never asked me if I wanted it. Probably because it's pretty pointless with manual locks. A
Sent via paper airplane
do you not care about your jeep? sheesh get a carabiner and clip it on a belt buckle:shaking:
LOL, free Jeep in CoCal if you can find it! Mine is parked inside under lock most of the time but when I'm on the road I'd like to have an alarm with a motion detector.
the green switch almost looks like the ABS/esp/traction control kill switch mod. it's tough to tell for sure though. the purple wire is what's making me think that.
when you turn the switch on (or off) do you get any warning lights on the dash?
check to make sure the traction control lights still work. push the traction control button once to turn it off and you should get a light on the dash, push again to turn it back on and the light will go off.
if the green switch controls the abs/esp/traction control thing you'll get that light again (as well as two others)
The green switch could be for a brake servo if it was used as a tow behind vehicle to activate the brakes from the tow vehicle? see if there is a trailer plug on the front of the jeep where they tied into the light's and brakes?
Not to Worry
If what you say is true, then the chances are you will not have the jeep long enough for it to be a problem. :shaking: Do you carry full coverage insurance?
In SoCal? Mine has 2 alarms, an auto tire deflater, the CLUB, bars on my windows, and I bury my keys (after I remove my winch) in the backyard. :shaking:
1 - 13 of 13 Posts
