I'm working on a project and I am comparing to metal shapes, both approximately 1.5"x3". The first is an aluminum rectangular tube and the second is a light gauge steel rolled "C" shape. What I am looking for is strength/load bearing capacity. Thank you for any help you can provide.
Normally any enclosed shape will have more strength than an open one. Not knowing the application, the sizes that you describe probably are not going to matter.
Discussion Starter · #4 ·
This is for a frame design that gets wrapped. (Kind of like a wing.) Although there will be some lateral forces, most of the force will be vertical only with lots of vibration. The steel would be 14 gauge and the aluminum would be 1/8" thick. The orientation of the shapes would be with the 3" dimension being vertical. Also, comparing a 6061 vs. 7005 alloy would be nice also.
Rectangular tube
