Do i have a factory amp? I have a 2009 6 disc, non-Infinity, 7 speaker system. I just ordered the 77kick10 speakers to go in prior to my or-fab cage. Figured while i was digging that deep it might be a good time to upgrade to the Dodge Nitro amp fix i hear so much about. I think the Infinity amp hides below the steering column so that would be an easy switch. But does the non-Infinity 6 disc sysem have an amp too, and if so, where does it hide?
I had an 07 that was a 6 disc... no sub... no amp. The amp will be under the steering column.
if you have a sub, you probably have an amp. the only thing that said "Infinity" on it was the sub. i pulled the bottom trim off and looked... sure enough, plastered across the bottom of the amp was "SOUND BY INFINITY"
