1 - 2 of 2 Posts
Full Traction 3" Premium-Flex Suspension System
Part Number: FTS7123H
2007 JK Wrangler (2 door model);Includes 5100 Series Hydraulic Shocks;Components are laser-cut for the best fitment to your new JK; Control arms are manufactured from durable 1-1/2" x .188 wall DOM steel tubing; Equipped with Full Traction rebuildable flex joints and long lasting polyurethane bushings; New-generation front sway bar disconnects; Ride-tuned coil springs; No driveline modifications are necessary
It says driveline modifications are necessary.Is this True?
It says NO driveline mods are necessary, but on a 2dr I would think it should read....."no immediate driveline mods are necessary, but some ___ thousand miles later they will fail."
Most will tell you you can get by with a 3" lift on a 2dr without driveline mods, but that your driveshafts will wear prematurely and need to be replaced at some poyint done the road. You may get 5k miles or maybe 50k, it just depends on how you use your Jeep.
1 - 2 of 2 Posts
