1 - 20 of 30 Posts
Hey gang…
Back in October of 2014, I ordered a couple of air chucks to experiment with so that I could make up a 4 wheel tire inflator/deflator. The air chucks had been sitting in the top drawer of my toolbox until now. I got busy on the project once again and finally up the 4 tire deflator/inflator.
These are the stay-on air chucks that I ordered. The one on the left with the lever is quite nice but it is just not as secure as the one on the right. The one with the lever has just a single clip and the one with the pull back collar has two clips and fits more securely. The one on the right also pushes onto the valve stem easily and you don’t need to pull the collar back to do this.
So fast forward from 2014 to earlier this week (May 2018) when I ordered the rest of the parts. I had been planning all along to use quality components. While you can order one long hose and cut it to fit using fittings and hose clamps for less money, I wanted a more “finished” quality to finished product so I ordered pre-made Goodyear hoses with a 10 year warranty. I also used a digital tire pressure gauge with backlight and rugged outer case. Rather than using the blocky brass fittings, I found smaller, more rounded fittings.
The Goodyear hoses are available in yellow, red or black. I picked yellow so that they are as visible as possible on the trail.
Everything coils up nicely and is just a little bit larger than a single 50 ft. air hose that you would be carrying anyway.
The lengths work perfectly and all hoses are equal length.
For my driveway beta test, I took the tire pressure down to 7 or so PSI just like I do on the trail. Air down was damn quick but I did not time this first try. Seems like it took about the same amount of time as it usually takes to deflate 1 to 1-1/2 tires. The pressure gauge will go to zero while you are deflating even though you are not at zero yet. Once you hit zero, close the valve off every so often to check where you are. I took it down to 7.5psi today at all for corners.
Air up took about 18 minutes using the ARB twin pump under the passenger seat. This was for airing up 4 37” tires from 7psi to 32psi – just like I do at the end of the trail. FWIW, this test was done at my house which is barely above sea level. With the TPMS system on my Rubicon, I was able to watch all four tires inflate real-time. Pretty cool.
The pressure gauge reads about 1psi higher than the actual tire pressure while you are pumping up. Shut the valve to see the correct pressure.
Parts list:
Qty 6, 6 ft. air hose:
https://www.amazon.com/gp/product/B0038MD180
Qty 2, 3 ft. air hose:
https://www.amazon.com/gp/product/B0038M4ZYY
Qty 4, lock-on air chucks:
https://www.amazon.com/gp/product/B008PZ7LMW
Qty 3, brass T fittings (for hoses):
https://www.amazon.com/gp/product/B074887122
Qty 1, brass T fitting (for gauge):
https://www.amazon.com/gp/product/B006PKKZ4U
Qty 1, brass ball valve:
https://www.amazon.com/gp/product/B00835X4NE
Qty 1, digital pressure gauge:
https://www.amazon.com/gp/product/B0783PYQ27
Qty 1, air hose adapter:
https://www.amazon.com/Tru-Flate-12-235-Female-NPT-Plug/dp/B000CFPYF4
That is awesome...
Thanks for sharing your ingenuity!
Thanks, man. I'm as happy to share the idea as I am to have implement it. Can't wait to try it at trailhead.
Please respond back to the thread if you fabbed one up yourself regardless of how you did it.
I absolutely will when I do my own. Great design... I can't see any reason why it wouldn't work with a C02 setup either. Any thoughts on that?
Thanks again!
Sent from my SM-G935V using Tapatalk
I have done a similar thing
it was nice to be able to use my power-tank regulator to set pressure and hook up to a set PSI but that was a bit slow so I end up only using it when I had extra time. It can also be set up to use a single tire deflator to do all 4 at once but again slower than one on each stem. However, it does make them all 4 exactly the same. If I set the tank up at a high PSI and fill them like you did with the compressor it goes quickly however again I found it faster to just air up all 4 individually and less to take with me. I have since started using the chuck parts for other projects. I may end up getting more and reusing one day but idk
Paul, very cool idea and great write-up! It woudl be cool to add a "set" mode regulator that would kick off the compressor once the pressure has been reached\equalized.
I had on my YJ with a York compressor a while back something similar to this:
Manual if your compressor alreay has an auto-shuttoff:
https://smile.amazon.com/dp/B000YC5IFG?tag=amz-mkt-fox-us-20&ascsubtag=1ba00-01000-s1060-win70-dsk00-smile-us000-pcomp-feature-pcomp-wm-3&ref=aa_pcomp
Or preset\adjustable
Barksdale Series CSP Compact Pressure Switch, Single Setpoint, 5 to 30 PSI, CSP12-32-13B - FLW, Inc.
https://www.northerntool.com/shop/tools/product_22938_22938?cm_mmc=Google-pla&utm_source=Google_PLA&utm_medium=Air Tools + Compressors > Air Compressor Parts + Maintenance > Air Compressor Pres&utm_campaign=Square D&utm_content=16151&gclid=CjwKCAjw8_nXBRAiEiwAXWe2yYrhQiH-pq9xIy4dCDol0_d1W4sDQ9QTEt-2FWIdQA3Pm6ukHrfh0BoCKR8QAvD_BwE
basically add on in line with the electric lines setup to power the compressor\ARB. Once it reached the desired pressure the compressor switches off.
Thanks, man.
I had been noodling over including a pressure switch for some time. Had another thread on it somewhere here.
I was actually thinking to go with a simple design sans regulator that was based on just an adjustable pressure switch. Something like this ("NC" or Normally Closed) stainless switch:
https://www.amazon.com/Stainless-Pneumatic-Adjustable-Pressure-QPM11-NC/dp/B00NXIXR60
So far, though, I am thinking that it may not be worth the extra hassle.
On air up with the pump running and the valve open, the gauge is reading real time and only reads about 1psi to 1.5psi above what it will read when the valve is shut.
I like to run my tires at 32psi cold all around. It has been my experience so far that just keeping an eye on the gauge and shutting the valve as soon as you see 33.5psi just works and the end result is the target 32psi.
Actually, I add a psi or two to my target psi at air up when leaving the trail because I am normally up at altitude when I do that and drive home to ~300' or so above sea level. Rubicon and Slick Rock are around 7,000' or so.
You are welcome to try this out yourself sans regulator next time we are out on the trail - after I air mine up, of course. ;)
Random Dude
I air up to 30.5 psi to get 28 psi cold (due to filling a tire with hot air which cools and contracts) if not changing elevation.
7000' elevation drops ~3.4 PSI from sea level (atmospheric pressure = 14.7 psi @ sea level, 11.3 psi @ 7000').
If I'm airing up then "getting good gas mileage" (driving downhill :laughing: ) for a few hours, I'll put in 35 psi and fuggedaboudit.
Discussion Starter #10
Just a couple of pics here of the storage bag. It's a perfect fit but you have to figure out how to roll it up perfectly.
It holds air quite well too and it works on one tire too when you connect just one hose.
It's time to QA test this on the trail!
while nowhere near as fancy as yours , I was inspired enough by this thread to go get some extra air hose from my garage & other air parts I had to make a 2 tire refill / balance air psi between the two . It is avhalf assed effort but can air up two tires at once or borrow 12psi from a full tire to the empty spare...it seemed like I was gonna wind up with a lot more hosecthan you have if I, too, built for all four.
:jeep2:
Discussion Starter #12
:jeep2:
Cool man. Two works as well.
But I've moved on. I'm wiring in a hood sensor to the factory alarm today. Thinking to add a proximity sensor too for when the doors are off.
I'm also trying to figure out the horn button wiring so that I can bypass the TIPM and have a fast acting horn. Picked up a Stebel Nautalis.
[/color]
we must be on similar Jeep mindwaves; our upgrades seem to parallel one another’s several times lately ,anyway...(I’ve gone thru it w Ken ( kjeeper) before, too).
I have browser history from past week that has tons of alt horn for the JK options data and info. Those Nautilus are one of the best, loudest possible. I have been lookin at the super low frequency horns.i like 330hz PIAA as just a sonic improvement . I don’t wanna add a second ,but it sounds better combined w. 440 or 550 Hz ..
I’m used to the delay we all loath w the horn by now but yours would address that w it’s own harness ,for sure.
:jeep2:
:jeep2:
pvanfab.com
Nice writeup. I have a similar setup for air up/down. The nice thing about airing up all 4 at once, is that all 4 tires will be exactly the psi. I have a York compressor and ran a hard line next to the frame from front to back and then quick disconnects at each corner. This way I am not laying a hose on the ground in the Iowa mud :( 4- 4ft hoses with the same clip on/stay on tire valves. I air all 4 tires in 3 minutes total.
Sent from my SM-G930V using Tapatalk
Discussion Starter #15
:jeep2:
:jeep2:
Yeah, I like the nautilus. The stock dual horn on my 2013 wasn't completely terrible. The reason I am relocating it is because the horn over by the master cylinder is getting displaced by a clutch master cylinder reservoir and the larger brake booster and m/c.
:jeep2:
Do you have a part number for those lock on air chucks? Do they work well?
Discussion Starter #18
These are similar to ones I use. https://www.amazon.com/Chuck-EUBags-Straight-Inflator-Gauges/dp/B07F13PZJQ
I'm using these because they grip from two sides versus one as shown in the pics above. i like that they are shorter too.
https://www.amazon.com/dp/B008PZ7LMW
I need a chuck that is 90 degrees from the hose.
The reason being is I have Method beadlocks where the valve stem is inside the spoke making for a very tight fit. Method ships with 45 degree valve stems so you can easily access them but I opted for short regular ones that allow me to mount the tpms sensors (Yes I want it to be functional!) as the 45 degree ones dont have a provision for that. I searched long and hard for 45 degree stems that have tpms provision and couldnt find them :frown2:
With the ones you guys have listed, I dont think I would be able to get the hose onto the stem. I would prefer the one @White13JKUR is using as it looks like it would hold better but I just dont know how it would fit in
Discussion Starter #20
The one I linked to is the one I ended up using. It is pretty short and lower profile than the other so you might be able to use a male-female elbow on it if you need to. I was using them on my trailreadys (now sold - can't take new pics) without issue and that valve stem had to be tilted out a little so I could slide the chuck on there easier.
The one I linked to screws right on to the hose.
1 - 20 of 30 Posts
