As stated by most of the good folks here you will be fine running your links and sway bar just like that! Just make sure to check for contact in any area of the travel.I ordered a set of rock krawler disconnects for a 3-4 inch lift thinking they would fit. I have a 2.5 teraflex spring lift with a one inch spacer. Should my sway bars be more parallel with the frame?
