1 - 20 of 36 Posts
Broker by the Minute
Ok by now someone has found the wonderful little happy dinger in the dash of the JK.
Where is it so I can kill it!:devil:
I have the manual and admittedly haven't had a lot of time to look but it HAS TO GO! So anyone found this little bugger yet?
the one that incessantly reminds you that your keys are in the jeep?
The one that makes you want to punch babies if you try to work on it with the doors open and the radio on?
yes, someone please find it.
I bet it's integrated into the computer tho............
On the TJ Wrangler it was part of the instrument cluster, so it will not be easy on the JK that is for sure:bawling:
There's a sequence of steps you do to change the other electronic settings (turn off the seat belt ding, change how the doors lock or unlock, etc). I wonder if there is a sequence to turn off all dings?
take out the battery. :D:D:D
sorry.... couldn't help myself. :)
i'm certain that the key-in chime is not going to be an option. considering that it is a "convenience" feature, it is more of a "safety" feature for us to help stop from accidentally getting off track and locking the doors with the kid(s) and keys in it. It happens ALOT to amny people, so ... trust me on that one.
At least with a soft top you can just unzip the window
pull the plug out on the door and use a wire to bridge them untill you find the wire that triggers the ding then cut it as there is no ding with the doors off
Disclaimer: i dont know if this will work as i just thought of it but i will probably give it a go
I believe the "ding" is externally generated and actually comes out of one of the speakers, driver front.....I think....
I reviewed th wiring diagrams for a couple hours looking for the dinger or the source. Everywhere where the ding comes from, i.e. key on everything goes to the CANBUS at some point and I see no indication of wiring going to a piezo electric noise maker or anything. So you are probably right John but I'll keep looking every time I find some spare minutes.
I'm going out to my Jeep now, I'll hold my ear to the speaker and let you know for sure.
OK, I was wrong, it's not coming from any speaker. I traced it by ear and it's coming from the instrument cluster, specifically from behind the fuel gauge.
If you have power windows, don't short the window circuit. Very possible fire hazard!
:shocked:
Discussion Starter #13
I want to kill the ding for other reasons than the door being a jar, which by the way it is still a door but not fully closed. :laughing:
I am not an ID-10-T (well most of the time) and don't need to know I have just put the keys in the ignition or they are still in the ignition. etc etc etc.
Heck I'd be happy to just be able to lower the ding by several dB's so I can only hear it when I WANT to hear it.
And the ding is so cutsey-pooh it makes me want to regurgitate every time I hear it. I'd rather have a buzzer as this ding is more like fingernails on a chalk board than a pleasant reminder.
I might have some time this weekend as the snow will still be flying and and I should get a chance on Sunday after a couple hours in the Hot Springs.
irate4x4 dot com
any new news on the noise maker?:smokin:
A chime warning system is standard factory-installed equipment. The chime warning system uses an electromechanical transducer and an electromechanical relay that are soldered onto the electronic circuit board inside of the ElectroMechanical Instrument Cluster (EMIC) (1) to provide audible indications of various vehicle conditions that may require the attention of the vehicle operator or occupants. The EMIC also includes the hardware and software necessary to serve as the electronic body control module and is sometimes referred to as the Cab Compartment Node or CCN.
The electromechanical transducer generates beep tones and chime tones, while the electromechanical relay generates click tones to emulate the sounds associated with conventional turn signal and hazard warning flasher operation. The microprocessor-based EMIC utilizes electronic chime request messages received from other modules in the vehicle over the Controller Area Network (CAN) data bus along with hard wired inputs to monitor many sensors and switches throughout the vehicle. In response to those inputs, the circuitry and programming of the EMIC allow it to control the audible outputs that are produced through its on-board transducer and relay.
The EMIC is capable of producing the following audible outputs:
  • Slow Rate Repetitive Click - Repeated click tones that are issued at a slow rate of about 90 clicks per minute.
  • Fast Rate Repetitive Click - Repeated click tones that are issued at a fast rate of more than about 180 clicks per minute.
  • Single Chime Tone - A single chime tone.
  • Slow Rate Repetitive Chime - Repeated chime tones that are issued at a slow rate of about 50 chimes per minute.
  • Fast Rate Repetitive Chime - Repeated chime tones that are issued at a fast rate of about 180 chimes per minute.
Hard wired circuitry connects the EMIC and the various chime warning system switch and sensor inputs to their modules and to each other through the electrical system of the vehicle. These hard wired circuits are integral to several wire harnesses, which are routed throughout the vehicle and retained by many different methods. These circuits may be connected to each other, to the vehicle electrical system and to the EMIC through the use of a combination of soldered splices, splice block connectors, and many different types of wire harness terminal connectors and insulators. Refer to the appropriate wiring information. The wiring information includes wiring diagrams, proper wire and connector repair procedures, further details on wire harness routing and retention, as well as pin-out and location views for the various wire harness connectors, splices and grounds.
The EMIC chime warning system circuits and components cannot be adjusted or repaired. If the EMIC circuitry, the on-board transducer or the relay are damaged or ineffective, the EMIC unit must be replaced.
a little work involved to do something about it
For me the main one is the no seat belt, I do drive in first gear fully in control a lot meaning under 10mph. And can't stand the ding. If you're in the passanger seat while the dinging is taking place, I may punch you.
the seatbelt dinger is an easy fix
theres a plug under the seat, just jumper 2 of the wires and it thinks its fastened all the time
If you want I can look at mine and tell you exactly which 2 colors you jump across
Yes please!! that is the one that is driving me mad......:bawling::pissed:
Discussion Starter #20
Ok so I mght not be able to pull it out but since it is a transducer I can muffle it. Now I just have to find it.:beer:
1 - 20 of 36 Posts
