So, at 7500 miles, went ahead and swapped out the oil, and the diff fluid. I like Royal purple, and used it in all of my previous vehicles, so I'm keeping with that tactic on the JK.
A few questions though:
(I have dana 35 front, d44 + LSD rear, 3.73 gearing)
1) My front diff fluid was a light tan, milky color with lots of little metal bits in it.
-> I presume the milky color means I got water in it? am I right here?
-> I presuming the little metal bits are from the gears being new and this being the first fluid change on the front diff? I pulled off about half an inch of metallic goo from the magnetized drain cap. Should I drain it again soon and see if I still get lots of metal?
2) The rear diff fluid was black, blacker than night. I'd guess this is because it gets a lot more wear from being always powered? It was a lot blacker than I had expected - think dino engine oil that's been run for 10k miles! I think it had plenty of metal in it, but couldn't really tell, it was pretty black. Not nearly as much material on the magnet as on the front.
3) I put 75-140 (Royal Purple) in both diffs - I know the manual recommends 75-90, unless doing heavy towing. I had a bunch of 75-140 left over from the commander, so I used that. Any known issues?
And, finally, a comment. It runs a LOT smoother now! Drove about 35 miles after swapping everything out, and it really seems to take off smoother. I wasn't getting "chatter" before, but I could feel something rough in the drivetrain when accelerating, and now I don't feel it. No chatter going around corners, so I'm presuming I don't need to add any LSD modifier.
!c
!c
