Truth. Dammit.Don't overfill them or you will be spitting fluid out of your breathers
The differential fluids were changed by the dealer before I bought the Jeep. That's what made me change the fluids...don't trust dealers.Don't overfill them or you will be spitting fluid out of your breathers
The correct amount of diff fluid should fit without going through the vents.Don't use the fill holes on the covers as your guide, you will under fill if you do. From memory, front = 1.35 qts, rear = 2.4 qts. Get as much in as you can through the cover hole, the rest through the vents. I switched to TF covers. They have dual fill plugs, saves the vent fill PITA factor.
The specified quantity may not fit, but yes, the stock cover's fill hole is at the correct height.The correct amount of diff fluid should fit without going through the vents.
This is the first time I've heard of this. How do you "know" that you are underfilling if you use the fill hole?If you use the stock covers' fill hole you will underfill, guaranteed. Try it for yourself. Vent hole filling for a full top up is pretty well documented.
Do you have a link or source to where it says to use the vent hole for topping off?...Vent hole filling for a full top up is pretty well documented.
Where?If you use the stock covers' fill hole you will underfill, guaranteed. Try it for yourself. Vent hole filling for a full top up is pretty well documented.
The axles are made by Dana and are shipped filled with oil, which is added with the cover facing up. The cover is a Dana-generic D44 part and is not specific to the JK housing. If you use the JK's fill holes you'll underfill the front housing by about .4 qt, the rear by about the same. This is worse if you have a lifted rig and corrected pinion angles, which as mentioned above effectively lowers the fill hole. As suggested, try it yourself and you'll get close to the same results.Are we to believe that the Chrysler engineer mistakenly placed the fill port on the diff cover to low? If anything i think that the hole was positioned correctly and the correct amount of fluid was determined later based on what fit. Who's got a service manual? A: what does it say and B: Can i have a copy or it electronically?
That's understood...that info is in the owners manual and well "documented"....FSM spec = 1.35 qts, front, 2.375 qts rear. This is also in the owners handbook.
