1 - 8 of 8 Posts
I have 4 pints front, 7.5 pints rear. Never had a problem with the rear overflowing, but have had at the front. During the cooler months I ran 4.5 pints or so in the front with no issues, but now it's warmed up I found that on long trips that was venting slightly, so I've dropped it back to 4 pints.
You definitely want more than stock, which is 2.75 pts front and 4.75 pts rear, to make sure the pinion/bearings get well lubed. With your lift you may need a little less than me, maybe something like 6.5 pts rear and 3.5 pts front.
FWIW I found syn fluid leaked past the axle seal in the front, so i run 80W90 dino up front and as the rear diff gets real hot, I run Mobil1 75W140 in the rear.
Discussion Starter · #5 ·
Discussion Starter · #7 ·
.....the rear diff gets real hot......
Obviously I got the covers. Thanks. Put them on last night and was going to fill tonight and head to Boulder Creek in the AM.
My rear diff fluid was burnt with only 2900 miles. It must get HOT. I might change the engine oil for the first time tonight as well......why not.
1 - 8 of 8 Posts
