1 - 20 of 27 Posts
A JKO DICK
Hello everyone,
I installed a DDM HID kit over the weekend. 55w, 4500k.
I have a massive flicker on just the high beams. I sent DDM and this is the response:
Some Jeeps have a pulsing system from the ECU to determine if a bulb is out; it can't be seen with a multimeter. It just causes the relay to chatter when the vehicle is running with the high beams on. To stop this, 2 parts are needed (available from most electronics parts stores): 220uF electrolytic capacitor (p/n 272-1029) and a 50v-1a silicon diode (p/n 276-1101). The diode gets installed on the high beam trigger wire to prevent spikes going back to the ECU. The capacitor gets wired between the high beam trigger wire and the ground wire. The capacitor keeps the relay engaged during the pulsing through the blue wire when the high beams are on and the vehicle is running. If there is flickering on low beam, then the same approach applied to the low beam circuit should be successful.
I've searched and searched and have found little info on exactly how to make the changes, but can't find anything. Does anyone know how to do what they are telling me to do and can explain it to me like I'm an idiot and of course pictures would help?
Please help me,
Gary
ok, im glad you posted this. iIm awaiting a DDM 35W kit in the mail. Iv used the 35W kit low beam kit in my G8, not flickering, ever! i hope that my DDM kit will not flicker at all. im Sud'd to see of anyone else has this problem.
A JKO DICK
The light is great, the flicker not so much. I'm wondreing if it's because I went with the 55w kit and not the 35w. Lot's of people had put them in their JK's and had no flickering. DDM isn't interested in figuring out why, they just send the (IMO) vague fix.
do you have the harness? from DDM? Its an extra 10-20 i think. Might help out a bit. I dont know why they wouldnt suggest that first! but i love to see, if mine flicker. i will do the resistors
I have the 55w 6000k low beam only and had a major flickering in the beginning and after a few seconds they were off so I bought some error code eliminator for $ 14.99 and problem solve.
A JKO DICK
I got the kit with harnes and ballast', but no error code eliminators. Are the resistors you're refering to the ones in the fix DDM sent me? If so do you understand what they are saying to do?
I have the 55w 6000k low beam only and had a major flickering in the beginning and after a few seconds they were off so I bought some error error code eliminators for $ 14.99 and problem solve.
The stuff I read said the error code eliminators didn't work for high beam flicker if the low beams work.
no, im not so good in the electrical area. Im trying ti out here and there, but not so good. you would need the schematics of both the harness on the jeep and the connectors on the lights themselves should be easy to get.
A JKO DICK
Haha! I realized theres not a lot traffic through here. Or I'm just blind. But yea i hope they chime in too. It really shouldn't be too hard.
Sent from AutoGuide.com App
A JKO DICK
Discussion Starter #11
Saturday Electrical/Lighting Guru Bump.
Please help educate us muggles.
My Hellfire HID's buzz on High, which I think is the same thing you are seeing. I can't see the flicker with my eyes. I tried Canbus Cancellers, didn't fix it. Only seems to happen when the engine is running
R.I.P. Mr. Nibbles!
Is it flickering or more of a pulsation? Cheap analog ballasts will pulsate.
This is one of the reasons why I'm not running one of these kits right now. The possibility that it's not gonna work and having to deal with a heaping of BS to get it going.
They sure are cheap and tempting though!
Hello everyone,
..... cut out....
Please help me,
Gary
When you say massive flicker is it from the high/low actuator moving/vibrating?
Do you get relay chatter?
Generally there are two possible root causes:
1.) The JK TIPM uses pulsing voltage in order to regulate the power supplied to the light bulbs in order to increase the bulb life and for DRL where used. This pulsing voltage (PWM) can cause visible flicker on LEDs or relay chatter. This flicker is most often only noticed while the engine is running since the off pulses are longer to regulate the higher alternator voltage down.
This type of flicker can be eliminated by putting a appropriately sized capacitor on the light circuit to smooth out the PWM.
2.) The JK TIPM employs current sensing and activates a on / off pulsing routine if it senses low or high current draw on the light circuits to avoid overloading the circuit at high current draw and detecting burned out bulbs or circuit at low current draw.
Pulsing caused by low current draw can be eliminated with load resistors on the light circuit to "simulate normal current draw".
I should be able to instal my h4 ddm today. I'll let you know how it goes.
EDIT, ok i installed them. the turn on fine then turn off, turn on for a few seconds then off. after 4 times they stay off. for the low beams. i turn on the high beams and a flicker on the left. then they turn off. so i think the error code eliminators are in order me. then the diodes.
Sorry to thread jack
Yep load resistors ( aka error code eliminators ) should get rid of the TIPM protection on/off routine.
FYI a diode is only used as a protection against back surge from the relay coil and does not eliminate flicker/chatter from PWM. Capacitors are to be used for flicker/chatter from PWM. Just note that the use of too high of a capacity capacitor on the high beam circuit will cause delays in high low switch over and could severely blind oncoming traffic even if you reacted quickly.
Hello everyone,
Please help me,
Gary
I have the same setup on mine, so I did a lot of testing, still testing some things out to simplify. But to help you out in your current situation. If you use the stock harness they sent you, assuming you wired it in on the passenger side closer to the battery. You will need a diode (1N4001 50V 1A) and a capacitor (4700uf 35V Electrolityc), I got mine from ebey very cheap. So the only circuit I modified was the two wires going to the coil side of the bulb, I put the diode inline on the Red wire (stripe/band goes towards the light), and the capacitor goes on both the red and black ( shorter lead with "-" goes on the black/ground wire). You can repeat this for the other side, just the wires are blue and black. I first did this on the one side and it fixed the seen flicker.
On mine before the mod, it worked fine with the Jeep off, but soon as you start it, it would flicker on high. If you look closely and listen to it you can see/hear the solenoid turning on/off for the high beams. From what I have gathered they use a pulsing power for the lights, can't bee seen by the eye, but by the time you add in a relay and solenoid, it can be seen.
1 - 20 of 27 Posts
