I have the Superior chrome-moly axles with CTM u-joints installed in my 2007 Jeep JK Rubicon Unlimited and looking to upgrade farther, thus selling assembled and at significant savings to you. I purchased my Jeep in 2007 with approximately 7,000 miles, installed the axles, and currently have about 9,500 miles. Thus, only about 2,500 miles on these axles.
Located in Keller, TX and I work in Fort Worth. 904-610-1620
CTM U-Joint
http://www.4wheelparts.com/prodDetail.aspx?partNo=CTMC145-1881&jeep-parts=true
· Price: $238.99
· Qty:
Part Number: CTMC145-1881
CTM U-Joint; 2007-09 JK Wrangler Rubicon;Dana 44 axle front axle;Rebuildable u-joint;Bronze sleeve that shows little or no wear
This CTM U-Joint could be the last U-Joint you ever have to buy! The rebuildable feature is unique in the fact that now as long as the cross or caps are intact then the seals bushings and clips can be replaced indefinitely! The U-joints are currently being used in rock crawling competition which is one of the most abusive applications we could find for testing. These U-joints are designed for use with full circle clips which means you will need to install them into some high quality CHROME-MOLY axle shafts. CTM U-Joints use a bronze sleeve that shows little or no wear. Keep these sleeves well greased using a needle adapter on your grease gun and abuse them worry free. Make sure you have all of your equipment set-up correctly to ensure a proper fit and superior strength to all other u-joints
Superior Axle And Gear Evolution Series Front Axle Kit
http://www.4wheelparts.com/prodDetail.aspx?partNo=SAGEV51LFS&jeep-parts=true
· Original Price: $532.99
See Our Price in Cart $506.34
· Qty:
Part Number: SAGEV51LFS
2007-09 JK Wrangler, Rubicon and Unlimited;Dana 44 driver side;Dual heat treatment for the ultimate in strength;High ultimate and yield tensile strength
The Superior Gear Evolution Series Axles are the only shafts to feature Dual heat treat and Torque Equalizing Diameter Profiles to allow the short side axle to have the same give as the long side, making for a more reliable axle assembly. Combine this with our rolled spline technology and a limited lifetime warranty and you will have the confidence to handle any trail.
http://www.4wheelparts.com/prodDetail.aspx?partNo=SAGEV51RFS&jeep-parts=true
· List Price: $559.99
· Original Price: $551.99
See Our Price in Cart $524.39
Qty:
Part Number: SAGEV51RFS
2007-09 JK Wrangler, Rubicon and Unlimited;Dana 44 passenger side;Dual heat treatment for the ultimate in strength;High ultimate and yield tensile strength
CTM U-joint (ea)
238.99
2
477.98
Superior Axle (driver)
506.34
1
506.34
Superior Axle (passenger)
524.39
1
524.39
TOTAL
$1508.71
**Warranty through manufacturer as indicated on their respective websites.
sorry I am all confused. How much are you selling everything for?
I'd like $1,000 so I don't pay additional for my swap... OBO!
